Question about AOpen AX4BS Pro (91.89J10.001) Motherboard
Computer monitor won't display.
I've made changes to my computer. I think the ram is causing the monitor problems. It won't display anything on startup.
  • 43 Answers
Hi when upgrading your PC ie mem card make sure there the right ones for it otherwise configaration automatic ily will be difficult . and the mem cards are to be in pair of same value .
thank you
Posted on May 25, 2009
What would cause a DELL Inspiron 580 that powers on fail to display anything on the monitor?
You were right that 4 beeps was RAM. Now though, if you're getting no display .. I'm wondering if something may have been bumped etc when you were having to get in the machine. You might want to reseat the video card (if not mainboard video). Note :: Before attaching or detaching monitor cables, be sure the monitor is off as well as the computer. Only usb is safe to manipulate with power on.
First step before doing anything is to make sure all power is off and disconnected from the computer .. and anything connected to it is off too. (not just in standby) .. ok, now that's done, continue..
I'd advise checking any other cables that could have been affected during opening / closing etc .. you may wish to pull & reseat any sata cables going to drives, remove and reseat the video card and generally make sure nothing is on crooked. Sometimes, even connections in a new computer can look fine but until reseated (disconnected & reconnected) they won't work quite right or intermittently.
Hope that helps get you up and going. If not, update here with any other info you may think of. Thanks.!
Jun 10, 2014 | Dell Inspiron 580 PC Desktop
Monitor not display anything and it lighs just keep blinking
Try re-seating the video cable. Try another monitor on this computer if you have one available. Try this monitor on another computer. That will narrow down where the problem lies. It's either the video card or the monitor which is bad. Of course if either is under warranty you may get a replacement, if not get your credit card ready :-) Good luck to you! =============== I would also look at the cable connection and see if there are any bent pins. This has caused issues for me in the past. Just be careful rebending the pins if any are bent. They are fragile and may snap off.
Jan 03, 2013 | Computers & Internet
My Gateway NV52 will not display anything on the screen. it stays black. The notebook powers up, but nothing is shown on the screen. How can i fix this?
First :
Try connect your laptop to other monitor ( crt or lcd ) if it looks normal on the monitor, it means your LCD laptop is broken.
Somestime often open-closed this LCD Laptop, may broken your Flexy data kabel of your LCD laptop.
Anyway Thx
Jun 23, 2011 | Gateway NV5215u Notebook
When I try to turn my computer on, it won't do anything. All I see is the gold light blink in the lower left corner.
Hi mcfarlandger,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 12, 2011 | Acer Aspire 5330-2339 Notebook
Monitor doesn't display any information. All hookups are in tact.
While it is still power on, unplug it from the video port of your computer. Can you see anything on the monitor? If so, the problem is with your computer. You need to troubleshoot. First try the monitor on another computer and verify that it's working fine. If it's not, then ask for repair and if it would cost some around $200, I don't recommend, you'll get a bigger and better new monitor for $200.
If you think there's nothing wrong with the printer and is tested ok, then start working with your computer, first try with another monitor and boot up, probably it shouldn't work, if it does, then the cable you were connecting the other monitor must be the faulty.
The best thing you can do with a dead video computer is to re-seat the Rams, Power connectors and Bios battery. First remove the Ram/s and boot again, you'll hear the beeping, means there's no ram installed. After cleaning the ram, again install it/ (if there are multiple rams, install only one), now boot again. same problem, try again with the other ram.
If you see no changes while working with the rams, then it must be the bios or the video card itself. If you have a spare graphics card, try it or if you don't have one, then the only solution is to replace the motherboard.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | HP Pavilion F1523 15" LCD Monitor
Hey who ever this is im having bad problems with my motherboard or my bios ive tried everything i got ECS C51GM motherboard with the 6100 nvidia video display. icant run any full screen programs cause it...
Its not a bios problem but on insertion of video card your ram got some tampered. Just reinsert the video card and your ram properly and now start your system. It might solve your problem.
May 20, 2010 | ECS C51GM-M Motherboard
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
Intel D865GLC computer problems.
Go back to what started the problem. You bought 2 1 gig ram sticks. My bet is they're either not matched ram that matches what you already had in your computer or is not compatible with your motherboard or the ram is defective and has bad memory addresses. If your computer has build in video card then it probably gets it's video ram from the system ram. A lot of the blue screens of death are caused by bad memory address although it can look like it's blaming the problem on a certain program or device driver because that is the program or driver that was atempting to use the bad memory address.
Jun 08, 2009 | Intel D865GLC Motherboard
No Display
Be sure that your power supply is working!
If the PS is working ,Try to examine your memory . if your computer getting long beeping. means that CPU is working if not beeping something wrong with your CPU. if beeping Unplug the memory clean it and connect it back. then test the computer. if doesn't solve the problem try replace the memory.
Dec 10, 2007 | Computers & Internet
AOpen AX4BS Pro (91.89J10.001) Motherboard Logo
56 people viewed this question
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Gareth Cockram
Gareth Cockram
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
