Question about McCulloch 10" Electric Pole / Chain Saw
How do you change the spark plug wire?
I have a McCulloch 10-10 and need to change yhe spark plug wire how do I do that?
  • 398 Answers
You have to take the coil out since it is connected to the wire and replace all of it. let me knwo if you have more questions
Posted on May 29, 2009
How do I change spark plug in my chainsaw
find where spark plug wire is connected to plug and disconnect very gently, remove spark plug with proper 13/16 or 5/8 wrench or socket and replace with new spark plug
Sep 16, 2014 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Hooking up wires on ignition coil on a mac-10-10-chainsaw
There are 2 items that you need to pay close attention to is the air gaps;
1. Air gap of the points, and
2. Air gap between the permanent magnet and the pick up coil.
Use the manual to determine the proper gap size.
Good Luck,
Rich Lilja
Jul 22, 2014 | McCulloch 1975 Pro 10-10 Automatic Chain...
Generator will crank but will not start
First check spark while cranking over( pull the plug wire hold by insulator about a 1/4 inch away from any ground, you should see a strong spark. then check to be sure the fuel is pumping from yhe carb., if no fuel try a short squirt into the carb intake. should fire up if you had spark.Its generally a good idea to put in a new plug and be sure to check the gap.
Oct 01, 2013 | McCulloch 11 HP 5700 WATT GENERATOR
How doesw one change the spark plug?
1. Push STOP switch down.
2. Remove air cleaner cover.
3. Disconnect the wire connector (G) from the spark plug
(H) by pulling and twisting at the same time (Figure 7-
5A).
4. Remove spark plug with spark plug socket wrench.
DO NOT USE ANY OTHER TOOL.
5. Check electrode gaps with wire feeler gauge and set
gaps to .025" (.635mm) if necessary.
6. Reinstall a new spark plug.
Here is the manuel with pictures as well:
http://pdfservicemanual.com/home-appliance/2006-2008-mcculloch-mcc1435a-mcc1635a-mcc1635ak-mcc1435a-ca-mcc1635a-ca-mcc1635ak-chainsaw-owners-service-manual.pdf
May 03, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My 7-10 doesn't have a spark any suggestions?
Try dissconnecting the earth cut outwire from the ignition unit and try again, this will rule out the wire and the switch, if there is still no spark with a new plug, then it has to be an ignition unit replacement
Apr 04, 2011 | McCulloch Garden
Need to know how to test coil, and need setting of coil to the flywheel. McCulloch 3200.
There are two ways you can check for spark.one way is to take the plug out and hook the plug wire to it and place it on the top of the head and pull the cord and see if plug fires.the other way is to use a spark tester.hook the tester up to the plug and plug wire then pull cord and see if light in tester lights up if it doe,s you have spark.the setting for the coil to flywheel is .010.
Dec 24, 2010 | McCulloch Garden
How to test magnito on McCulloch 310 chainsaw
The only way to test an ignition module on any small engine is on the machine. Simple and easy.First remove the spark plug , then remove the wire that connects the module to the kill switch, its located right next to the plug wire above the laminations. Put a spark tester in the pkug boot and ground the other end. Pull the rope and look for a spark. Its that simple. If you have a spark, check the switch and wire, if you dont,check the grounding screws that hold the module to the block for a clean contact.If you still have no good spark its time to replace the Ignition module (coil).If you dont have a spark tester, ask someone dumb enough to hold it. If they jump and cuss you out you know you have a good spark
Nov 15, 2009 | McCulloch Garden
Fr2.0 14'' McCulloch chainsaw has no spark when holding spark plug wire while pulling the cord.
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
If you really sure there is no spark turn on the ignition, put your pinky finger in place of the plug, and give a short pull. If you didn't get shocked the coil, switch, or wiring is bad.
You can find an IPL for your saw here:
McCulloch International
http://www.mcculloch.biz/
The model you provided does not cross. A number on your saw will match something. Your coil part number can be found there. HTH
Lou
Oct 15, 2009 | McCulloch Garden
I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Oct 08, 2009 | McCulloch Garden
McCulloch 10" Electric Pole / Chain Saw Logo
284 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
