Tv repair I need to know the value of resitor 1900u on the main board of ge television. the model number is 27gt613fe2. can you help me please jim
  • 3 more comments
  • jdholk Oct 25, 2007
    Terryfic
    the R1900u resitor was burnt so badly that i cound not read the value.  the size of R1900u says that it is more than 1/10 watt.
    Please look again because R1900u is in the same spot  on the ciruit board as R1901.  The notation for R1900u is up and to the left of R1901.
    Thank You
    Jim
  • jdholk Oct 26, 2007
    terryfic
    there is only one resistor on the circuit board R1900u.
    r1901 is for other model tv i think.
    R1900u is bigger physicaly may be 2watts
    jim
  • jdholk Nov 03, 2007
    sorry it took so long...T
    the chassis number is CTC1778H2
    thanks Jim
  • jdholk Nov 04, 2007
    I am a little faster this time
    after a closer look the cassia number is CTC77BH2
    sorry about that
    Jim
  • jdholk Nov 10, 2007
    the chassis no is CTC177BH2
    Jim
    Genius:
  • 1,694 Answers
Jim, looks like you are in u1901 audio o/p IC circuit.
Could not identify R1900...there is an R1901 value== 1K,5%,1/10watt. let me know by rating this response...T.
Posted on Oct 22, 2007
  • 1 more comment
  • Vista Electronics Oct 25, 2007
    Are the two resistors R1900 & R1901 wired in parallel??
    And,are they the same physical size (wattage) ?? then try
    measuring R1901 and use the same value for R1900...T.
      PS. By experimenting a little,I don't think you will damage the set. I take it the picture is fine and you are fixing audio......
  • Vista Electronics Oct 27, 2007
    JIM, give me the chassis number....T.
  • Vista Electronics Nov 04, 2007
    Is that CTC177H2 ?........
I have an older model LG TV that gets a perfect picture and sound for about 15-20 minutes, then goes to a black screen with various lines and no sound?
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Jun 10, 2015 | LG 32LC2D Television
The TV is freezing on the logo screen when the TV is turned on.
Corrupted firmware. A firmware update is necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 07, 2015 | Vizio L32 32 in. LCD HDTV
My emerson tv keeps turning its self off after a few seconds
I do not have a model number to go with. But I would imagine this TV is still on the new side. If this is the case, the values on the starting resistors for the inverter board have changed values. You will need an inverter board replaced. Or if you know of an authorized Philips Center, they may replace the resistors with the same value or new values, depending on the model number of your TV. Thanks for asking and show a few hands of support!
Feb 28, 2011 | Emerson Televison & Video
TV screen went black/ red blinking light
LOOSE CONNECTIONS ON THE MAIN BOARD! OR CHECK FOR A YELLOW FLAT CAPACITOR IN THE FRONT OF THE MAIN BOARD NEAR THE CRT'S. BURN'T, PART VALUE, 1200PF-2KU
Mar 16, 2009 | Toshiba 50H81 50" Rear Projection...
The colors are out of alignment causing the screen to appear 3D.
yes you can try.
goto convergence setings
slect menue on your remote
goto Convergence option 4 under (screen)
if this mode is mising you have an open resitor 750k ohm location on main pcb board is R19722
your tv set is also an RCA tpk195, if this helps
ptk195.
you might want to have a TV repairman look at the red blue and green convergence amp's.
hope this helps you.
regards,
daniel.
Jan 11, 2009 | GE 46GW 948 46" Rear Projection Television
TV keeps losing sound
Please try to check the secondary PSU second & sound board electrolytic capacitor with their ESR value too. More info on repair lcd tv, here is the site you must visit: www.lcd-television-repair.com . Hope this help.
Dec 01, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
