Question about Hotpoint WMA44 Front Load Washer
Hotpoint washing machine belt come off
The belt has come off both the pulley and the motor how can i get this back on ???? Great advise, worked brilliantly.
I struggled before deciding to search on the net for help.
Just one question: Why does the belt slip off in the first place?
  • ndola19 May 25, 2009
    Thanks sirwriter.
    I will check your suggestions once the machine has completed it's full cycle. It is currently running without any problems (touch wood).
    Once again, thanks.
  • 323 Answers
Either the motor has loosened enough from its mounting to shift to an angle instead of being straight in alignment to the pulley, or the pulley has . Whenever a belt pulley becomes misaligned or is shifted to a slightly off angle position, the belt will seek and climb up the edge that is out of alignment and make its way off.
The only other feasible explanation is that the motor or pulley has become loose enough in its mounting to slide one toward the other. A belt turning without enough tension to keep it tight and flat will, through centrifugal force, raise up enough out of its path to find the slightest misalignment and work toward that edge until it comes off.
Until this situation is corrected it will eventually find its way off again.
Posted on May 25, 2009
The belt has come off my hotpoint WMA5 washing machine
offer the belt around the motor pulley first , feed one side of the belt to drum pulley , whilst holding this side to drum pulley turn pulley using other hand , belt should follow natural path onto pulley .
Jan 23, 2013 | Hotpoint Aquarius WMA56 Front Load Washer
Replace belt on Hotpoint Aquarius WM31 washing
Hi.
Remove top cover of washer.
Remove rear access panel.
Slacken off the motor fixing bolts, and pull motor towards drum top.
Fit belt round motor pulley first, and then feed it round the drum pulley from the rear of the washer.
Tighten motor bolts just enough to hold motor steady, and pull motor towardsa cabinet side to tension belt, it needs to be farly tight.
Then tighten motor bolts securely.
Fit back top and rear covers.
Apr 05, 2010 | Hotpoint Washing Machines
How to change the belt on a hotpoint wma54 washing machine
there is a rear access panel in the center of the back,remove this cover and put the new belt on the motor pulley,then over the larger drum pulley,it takes some strength unless you release the motor tensioner and retighten after the belt is on
Mar 23, 2010 | Hotpoint WMA54 Front Load Washer
Yeah hello there , im trying fitt a belt two hotpoint washing machine wf100p , i havn't taken the back off putting the belt on the motor first the on two the drum wheel gradualy turning the wheel to put...
You are doing the right thing. Hook the belt onto the motor pulley, then onto the main pulley as far as it will go, use a few cable ties to hold it on the pulley and turn the drum anti clockwise, the cable ties will snap as the pulley turns. Hotpoint have made a tool for putting these belts on but you woudn't want to pay out just for one belt.Belt fitting Diagram link
Mar 16, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How do i fix on a drive belt to a washing machine?
There is a removeable cover at bottom rear of washer..
Undo this, and you will see the motor and belt.
It will be very tight to put on, but this is normal as it is a stretch belt, that is why there is no adjustment on motor.
Hope this helps you .
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Aquarius WF220 Front Load Washer
HOW DO I FIT NEW BELT TO HOTPOINT WF430 WASHING MACHINE
The easyest way to fit these belts is to locate it on the motor pulley and as far onto the right hand side of the main pulley (viewed from the front of the machine) as possible. Hold it on the main pulley with a cable tie and rotate the drum anti clockwise by turning it from inside. The belt will be drawn onto the pulley and the cable tie will snap as it rotates. (Easy)
Jun 17, 2009 | Hotpoint WF430 Front Load Washer
To refit belt, remove top cover and rear lower panel at bottom of washer.
Tilt the m/c towards you.,you may need assistance to hold m/c.
Put the belt round the motor pulley first, and then fit it on drum pulley, slowly turn the pulley feeding the belt round as you go, it will be very tight, so be careful not to trap fingers., just keep going until belt is on, there is no adjustment needed as belt is self tensioning.
The belt needs to sit in the middle of the pulley.
Plz rate my solution.
Thanks.
Jan 10, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
u need to take the lid off and keep the small panel off now 2 ways u can do it 1)undue the botls on the motor just enough so u can move the motor now put the belt around the pulley wheel by placing your hand through the small panel once done put the belt around the motor wheel now last thing pull motor so it tightens the belt and tighten the bolts on the motor 2)place the belt around the wheel on the motor now with your other hand put the belt on 1 side of the big pulley wheel and hold it in place as u turn the pulley wheel it will slide on but with tension once on spin the pulley wheel and it will line up the belt
Dec 29, 2007 | Hotpoint First Edition FEW12 Front Load...
How do I replace the belt that makes the drum spin on a Hotpoint Ultima WF860 ?
The belt goes around the drum and onto the motor pulley. No need to loosen anything. Put tension on the belt and fit it onto the motor pulley by gently turning the motor and pushing the belt onto the pulley at the same time.
Oct 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA44 Front Load Washer Logo
205 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
