Question about Epson LX-300 Matrix Printer
XP Cannot able to print on Epson LX 300+
One of my pc has two o/s one is windows 98 and from this o/s epson LX 300+ Printer works normaly... when i boot in xp it cant print, no error messages comes where it is work with another same configuration. i have check the following in computers.
1. parallel port (ECP and EPP)
2. download the driver for the same and reinstall it.
3. format the PC and reinstall XP.one of my pc has two o/s one is windows 98 and from this o/s epson LX 300+ Printer works normaly... when i boot in xp it cant print, no error messages comes where it is work with another same configuration. i have check the following in computers.
  • 35 Answers
This is XP's parallel port problem
try changing the settings:
find: Start Button, Control panel, System
Device Manager, then Ports !
Change the settings for LPT1 to enable
Detection of Legacy Plug and Play devices
o and Here is the service manual for this printer:
http://ca.geocities.com/artiedc/LX300SvcMan.pdf
Ed
Posted on Jun 17, 2009
Printer does not print on windows 7 operating system
Thanks for contacting Fixya.com.
As a veteran Epson user, I can usually find out just what Epson offers in the way of drivers for any of their printers, depending upon the version of operating system is requiring printer drivers. This is no exception with the Epson LX 300+.
Unfortunately, Epson only made drivers for the LX 300+ for Windows OS XP and earlier. As of current there are no drivers for PCs with Vista or Windows XP made for the Epson LX 300+.
Here is the link directly from Epson's Printer Drivers & Support page for the LX 300+
Epson LX 300+ Drivers & Downloads Page
If you truly need another Epson Impact Printer which is possibly windows compatible, I would recommend visiting the link below in order to find a more Windows 7 comparable model, if there are any.
Epson Support -Impact Printers
I hope this information does provide you confirmation of what you have been seeking for this printer model.
Regards,
-Mactectrainer
Aug 19, 2010 | Epson LX-300 Matrix Printer
Epson lx 300 dot matrix printer not printing properly
Make sure you installed correct printer driver and choose the correct model .and remove the pending print job if it is there.
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | Epson LX-300 Matrix Printer
Epson LX-300+ ''please insert paper'' error on Windows 98 system
try using an older driver from epson, sometimes you can luck up and find one that will work. try and find the prior model the one it replaced and see what happens. any of the 9x drivers should work try several just because one won't dosent mean another wont. hope this helps
Jul 16, 2009 | Epson LX-300 Matrix Printer
Poor print quality of pdf documents on Epson LX-300
PDFs are designed to print using Postscript language.
The problem will occur with any non-Postscript printer. You can get better results on Windows printers by clicking on the "Advanced' button in the Print dialogue window. Then check 'Print as Image'.
This has worked well for me.
Dec 10, 2008 | Epson LX-300+ II Matrix Printer
Not Printing Correctly
Try reinstalling the printer driver using the CD with label on it LX-300+.
Sep 25, 2008 | Epson LX-300 Matrix Printer
Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Draft Printing with EPSON LX-300 with custom page 10x6 inch in windows xp sp2
You have to install the printer through it installer, it that way the advanced features of the printer will be activated and can be manually configured to what you want.
Click the link to get your driver. download here
Don't forget to rate me, "Fixya"... thanks.
Jan 27, 2008 | Epson LX-300 Matrix Printer
Windows xp printer install
Hi, Have you tried the Epson driver "ep10759.exe"? It is available at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14250&prodoid=8192&infoType=Downloads&platform=Windows It this still doesn't workout for you, pls post back as to how you connect the 810 to your PC (USB or LPT/Parallel), Good luck and kind regards.
Oct 08, 2007 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
443 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
