Question about Hayward Pool Products Hayward 400k Lp H Series Spa & Pool Heater
Hayward H Series 400,000 BTU Pool Heater Won't Ignite
IF code appears, heater starts up and shuts off after two seconds; Can I try lighting manually, to get it going just for today, and if so, how do you light it manually?
  • Anonymous Mar 29, 2014
    heater will not start
    error code 68
  • 15 Answers
You can not manually light it. Open the front cover look for the gas nozzles brass looking on a tube. on the right side you will see a wire going to a sensor above the next to last burner take the nozzle out for that burner. 7/16 wrench unsrcew the nozzle and see if it is clogged. use something soft to push it out. Spiders love to lay eggs in these. Spray with WD40 and reassemble should work now
Best of luck
Posted on Jun 23, 2009
  • Mike Bailey May 27, 2012
    BRILLIANT! 6 out of 8 of my jets were clogged with that white spider discharge. Took each one out, cleaned them, WD40'd them, reinstalled them... and WHOOOPH! Fired right up! I wish I knew how much $ you just saved me!!! (took pics - if anyone wants 'em, message me. THANKS AGAIN!
Hayward Pool Heater won't light?
Clean the gas jets of white spider guck! After shutting the gas off, loosen the two front cover screws and remove it, use a 7/16 wrench to unscrew each jet (8 on mine), clean it out with a pipe cleaner something similar, WD40 it, and reinstall.
Posted on May 27, 2012
    Problem Solver:
  • 9 Answers
IF is ignition failure,
and no you cannot light an electronic heater manually, there is no standing pilot.
check gas orifices for blockage, if not tou may need to replace HSI
Posted on Jun 18, 2009
SOURCE: Pool heater burners won't ignite.
Also you need to inspect the igniter.
Posted on Apr 25, 2009
  • 83 Answers
SOURCE: I have a Laars Lite 2 400,000 btu pool heater. It
It could be that the Igniter has gone bad. Or it cold be a number of other items, like the gas valve itself. If the heater has a display panel on it, is there an error code showing? If there is, go to your Owner's Manual and find out what the code is for the heater.
If you do not have a manual, you can find one online at the following link:
http://www.inyopools.com/owners_manual/jandy_heaters_lite2.pdf
Posted on Jul 08, 2009
SOURCE: Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Posted on Sep 16, 2009
thepool
  • 78 Answers
SOURCE: Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
Posted on Apr 23, 2010
  • 64 Answers
SOURCE: H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1: how do i fix the AO code on my hayward heater?...
AO will apply to your blower, blower tubing, or blower vacuum switch. You need to check these items.
Posted on May 20, 2010
H400ed2 IF
(IF- Ignition Failure) It may be your flame sensor failing to recognize that the heater has fired. This will tell the gas valve to close if it does not detect a flame.
Dec 06, 2013 | Hayward H Series Pool & Spa Heater...
My hayward h400ed2 heater starts for 2-3 seconds then shuts down showing error IF. I checked the gas orifices - they all clean. Heater was working fine fo the most of the summer then started showing IF...
Have you installed anything in your home that uses gas? Alot of times it due to low gas pressure.
When you checked the orfices did you actually remove them? or just stick a paperclip inside and clean them?
If the heater is firing ..even for 2-3 seconds the ignightor is fine. If it wasnt it wouldnt lite, period... bad call on hayward
Aug 22, 2010 | Hayward H Series Pool & Spa Heater...
Try to start heater and i get a code that says service ags what does this mean
Automatic gas Shut Off . The system Locks out if it does not ignite. Shut the power off to the unit at the breaker then try to start it again.
Jun 20, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
check pressure switch,if it is faulty or out of adjustment it wont allow it to go tomain burner
Jun 17, 2009 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward Pool Products Hayward 400k Lp H Series Spa & Pool Heater  Logo
945 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
