Question about Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook
Adaptor light on. Laptop does not start when power button pressed same problem also when try too start from battery power. Son was playing a pc game and just switched off, have waited for hour still n
I have power from adaptor, light is on. Laptop will not start when power button pressed same when on battery only. Can you help Mark
  • 249 Answers
Try to take out both battery and power adaptor. press and hold the power button for ten secods while both are not connected. then connect the power adapter only. try to turn it on. if it still does not turn on then most likely you have a problem with the hardware. you might need to have it checked out with an outside tech already.
Posted on May 25, 2009
Why My Inspiron mini will not start?
It is unfortunate that the computer is not turning on. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check hoe the Power LEDs on the system, battery and AC Adaptor react. Then I can check and help you further.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 22, 2014 | Dell Inspiron Mini 10 Notebook
Adaptor and battery is good but laptop does not power up.it shows no sign of power
Make sure the battery is fully charged from the other laptop and then try to start it up with the battery only and then try with the plug only and see if there is any activity.
Jan 22, 2014 | HP Pavilion g6-1a50us 15.6in Widescreen...
No power in my laptop. I press power button and only see red battery light for few seconds.
please measure the output voltage from the adapter , see the label printed in your adaptor if the voltage read with the exactly voltage: exampe label printed: 17.8, and you measure 17.8 the adaptor is o.k
If do not the adaptor is faulty. repair or replace
However you must try with the battery to Start, of course the battery must be charged in full, if the battery is o.k the laptop will be on. If not the power supply inside is faulty. REPAIR.
God bless you
Jul 30, 2013 | Advent Modena M101
Every time I turn it on, it displays nothing, just a black screen.But the power indicator is on and there are some white lights flashing next on the Caps lock button and above the scroll button..
Dead (ish) Laptop.
Press the power button momentarily to check if it is hibernating or in stand by. If this doesn't work;
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine and the laptop still won't start, then you may have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Feb 04, 2011 | Computers & Internet
Acer laptop will not boot up
Dead (ish) Laptop.
Hope this helps.
Feb 04, 2011 | Acer Aspire 5610-4648 Notebook
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
Hey i have pressed ctrl + F12 by mistake and my loptop stop charging the battray now as the battrtay run out i can not start it up, it is pulged to the power but it wont light and when i press the strating...
Pressing Ctrl + F12 should not have caused what you are saying.
Check your power adaptor is there a light on the power adaptors case if not check the fuse.
Is there a light lit anywhere on the laptop when the power adaptor is plugged in.
If you have lights on the power adaptor but not the laptop have the output of the adaptor checked.
If you have lights on the adaptor and laptop try the following.
One trick that can re-set things is to remove the RAM, HDD, Battery and power adaptor, fit it back together and try to power up.
Hope this helps.
Feb 17, 2010 | Sony Computers & Internet
Laptop wont start ... ( Presario 700 )
chk your ac adapter bro .. i think its not working
Aug 27, 2008 | Compaq Presario 700 470024-192 Notebook
Laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
My laptop amilo m-6100 wont start up
although I never tried it, I dont think you can operate a laptop with no battery, even when its connected to AC.
Jan 02, 2008 | Fujitsu AMILO M-6100 Notebook
Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook Logo
265 people viewed this question
Alun Cox
