Panasonic NV-DS60 Mini DV Digital Camcorder
Problem for Panasonic NV-DS60 Mini DV Digital Camcorder
Completlly stop working after wrong polarity lead been plugged In
By avar on May 25, 2009
Hi accidentally used a wrong polarity lead from a 7.6 v DC power supply
plugged in to nv-ds60, after that no more response, pulled the circuit board out under the battery, trying to find a fuse or protraction circuit, find a component call FL1201 but still got a circuit through.
is there any other fuse or protraction device? what damage it down when the supply is wrong polarity?
Any one can help me? how to solve the problem?
thank you
Comments:
May 25, 2009
- thank you for the solution, I will have a good look again.
Jun 21, 2009
- Thank you for the advice it actually blow the smaller fuse, I followed the circuit found the fuse and bypassed and it worked again.
thank you for you help. appreciated.
Alex
Solution #1
posted on May 25, 2009
Not Rated)
GenxHouston
Rank: Apprentice
Rating: 0%, 0 votes
one of the first things that go are is the protection diode coming off the + input. Then a fuse and so on. Surface mount fuses are light in color (usially green with white text). Attempt to bypass these components with a small wire or paperclip. Once you follow the lead from positive input you will run into a black rectangular block about the size of a grain of rice with 3 leads. That will be your voltage regulator. Its set at the correct voltage, and since you already have a power supply with a set voltage, then you dont need it. Its also the first thing that blows when you switch polaritys. (voltage regulators have 3 pins - input output and ground) when you switch polaritys that ground becomes the "input" and ..... go to all http://www.alldatasheet.com/ and type in the text you see on that component. It will then identify the component and list its voltage output and at which pin.  Apply set voltage to lead and ... pray?
Best of luck.
Was this helpful?
Yes
No
Popular Solutions for Panasonic NV-DS60 Mini DV
Questions and Unsolved Problems for Panasonic NV-DS60 Mini DV
Do you recommend Panasonic NV-DS60 Mini DV Digital Camcorder?
Answer
Answer
When I try to playback or record I can't see anything I have got tapes that I know have stuff on but... (More)
Answer
How do you upload to a PC from a Panasonic NVDS60 video camera?
Answer
I have a nz-ds65a. When i playback cassette it stop after 10 sec and the power light flashes
Answer
hi i have a panasonic nv-ds60 digital camcorder, when i try to use the camera for any function be it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic NV-DS60 Mini DV...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
