I OWN A MATSUI MP3 PLAYER (MODEL NO:MAT 105MR). WHEN I POWER ON THE
DEVICE IT DISPLAYS "INTERNAL CHECK DISC" AND THEN POWER FAILS. THIS
REPEATS UNTIL I REMOWE THE BATTERY.wHAT I8S THE PROBLEM & HOW CAN I
FIX IT?
I suspect that the firmware has corrupted or disappeared. I can sometimes do an explore on it, and only music shows up. No other folders. I have tried to find firmware to reload it, but so far have been unsuccessful.
On Start up, it shows the Matsui logo, then goes into.....Creating music. library file. Sometimes it hangs there, and at other times, shows that there is an error, and needs to be re-formatted. Tried a re format, but it comes up as unsuccessful.
Anyone know where I can get fresh firmware, and also how to install it?
Regards,
G.I have the same model MP3 player.
SAME PROBLEM SHOW INTERNAL CHECK DISK AND SWITCH OFF SAME PROBLEM SHOW INTERNAL CHECK DISK AND SWITCH OFF
AnonymousDec 27, 2007
OWN A MATSUI MP3 PLAYER (MODEL NO:MAT 105MR). WHEN I POWER ON THE DEVICE IT DISPLAYS "INTERNAL CHECK DISC" AND THEN POWER FAILS. THIS REPEATS UNTIL I REMOWE THE BATTERY.wHAT I8S THE PROBLEM & HOW CAN IOWN A MATSUI MP3 PLAYER (MODEL NO:MAT 105MR). WHEN I POWER ON THE DEVICE IT DISPLAYS "INTERNAL CHECK DISC" AND THEN POWER FAILS. THIS REPEATS UNTIL I REMOWE THE BATTERY.wHAT I8S THE PROBLEM & HOW CAN I
I have matsui mat110mr and it also has the same problem. When I switch it on first it shows matsui logo then it show the messege " internal check disk" and restarts and again does the same repeatedly untill i remove the battery. I dont know what the hell has gone into it!I have matsui mat110mr and it also has the same problem. When I switch it on first it shows matsui logo then it show the messege " internal check disk" and restarts and again does the same repeatedly untill i remove the battery. I dont know what the hell has gone into it!
AnonymousMay 09, 2008
I have a matsui mp3 player model mat110. when i power it on it just displays the word MATSUI. Even when i remove the battery.
What should I do?
Sunday I have a matsui mp3 player model mat110. when i power it on it just displays the word MATSUI. Even when i remove the battery.
What should I do?
Sunday
You can't post conmments that contain an email address.
I've spent 20 minutes googling matsui>mat110>user manuals>drivers and came up with nothing. I could not even find help at the Matsui web site. I did find several threads on different sites complaining about the lack of documentation. If you have a phone number for them I'd use it.
Sorry and good luck.
If your Matsui is working suggest you leave well alone -- I've been looking for utilities (new firmware, reflash utility and firmware extractor) and it's all very confusing.
Apart from the ghastly menu system the only problem I've had with mine £8 ($16 used from a flea market) is that Win XP's data write-behind feature means that XP merrily suggests that file transfers are complete when the player is still digesting the files. If you interrupt this by mistake XP stops responding or complains that data has been lost.
If you can check the rechargeable batteries try that. If you plug it into a wall socket with the adapter and nothing happens you might have other major problems. Just a little education: when you buy something especially from other countries alway check it before leaving to make sure it works. Unless there is a company that you can send the warranty unit to you may be out of luck. Sorry.
Regards,
G.
What should I do?
Sunday
