Question about HP iPAQ HX2110 Pocket PC
Touchscreen problems (HP RX or HX series)
Hello experts, Another RX 3715 came to me, another problem. This one staid in a cold environment over the night and next day it begun to manifest the problem. It woun't allow the user to properly allign the screen, it will respond to taps with a certain delay but it woun't pass the "allign screen" setup. I managed to check up the display and it's ok, both digitalizer and connector, I have made a swich to another RX3715 and the problem is still there. Does anyone know what component could cause the problem. A full firmware reflash didn't do the job for this pda. Is there any other method to diagnosticate the motherboard, like running a console program like MTTY to acces the primary memory controller (firmware) in order to make a diagnostic of the motherboard? This problem and the solutions could help other users who have HP HX and RX series PDA's as most QVGA models use the same memory and display controllers. Have the same exact problem on mi iPAQ HX2110: touch screen doesn't recognize touches anymore. Is there anyone that knows a fix for this? Thanks in advance, Davide (davide.gallina@gmail.com)
    Novelist:
  • 164 Answers
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
Posted on Jul 24, 2009
Download driver for hp ipaq rx 3715
Hi!
You can download the drivers for your hp ipaq by clicking on this link.
Under the window it will open the extreme bottom there is a download link.
Thanks
Rylee
Jan 29, 2009 | HP iPAQ RX3715 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
Helo i have a problem
The dreaded "allign screen problem" strikes again. This is a known bug of these rx ipaqs. You should simply try to see if the ipaq passes this stage if you try to allign the screen a few times. If not, try a firmware update/rom update (from the hp site) If this woun't work then the problem is located on the motherboard,where a small chip called the touchscreen I/O controller has failed. This isn't fixable by replacing the screen, only the whole motherboard. Unfortunately most of the first generation rx 3715 units (first revisions) carried this problem just waiting to happen.
Please ask more details if you need to better understand any of these methods above.
Jul 11, 2008 | HP iPAQ RX3715 Pocket PC
IPAQ Rx 3715 Internet settings~ conectivity problem
I have a few thoughts.
Occasionally, for no apparent reason, the ipaq will "forget" your password. Try re-entering it.
The other option is to try a program called Kasuei Hitchhiker. It is a more powerful and easier to understand interface than the normal ipaq one. you can download it here.
http://www.freewareppc.com/communication/hitchhiker.shtml
Hope it goes well! I'll try again if this does not work!
Aug 29, 2007 | HP iPAQ RX3715 Pocket PC
Bogdan, could you give me a solution to contact you about this PDA? Give me your email adress or your cell phone number (mine are tiby_olimp@yahoo.fr and 0746761410)
Jun 09, 2007 | HP iPAQ RX3715 Pocket PC
Ipaq totally dead after leaving it in my car for two weeks, temperature down to -6C
Its possible (but not likely) that when you took it into a warm room condensation built up inside it. Try removing the battery, memory cards and letting it sit in a warm, dry environment for a few days and try again. If nothing changes I suspect that a component has failed, but -6F is still within the operational range of commercial electronics. If your device is still in warranty then I would call HP up and ask for a warranty replacement. Let us know if you have any other questions and please don't forget to rate this posting.
Feb 12, 2007 | HP iPAQ RX3715 Pocket PC
Data access problem with SD card for rx 3715
SD cards can be tricky. One good program that I like is pocket mechanic..... http://www.pocketgear.com/software_detail.asp?id=12178&associateid=373.
Sep 14, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ HX2110 Pocket PC Logo
200 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
