Question about HP DesignJet 110 Plus InkJet Printer
I most likely put in faulty cartridge and printer started beeping..i took faulty cartridge out and switched off printer and repalced with new cartridge..and it still beeped..is there a way of rebootin
I have an HP designjet 110plus nr..i put in most likely faulty cardridge...machine beeped..then replaced black cartridge with another cartridge...but it still kept on beeping, even after i have rebooted it..can u pleas advise me to re boot so that it can stop beeping?
  • philesia May 25, 2009
    same as above....only cyan colour is showing,i cleaned printer heads,they are not flashing..... i held in power switch on for 2 minutes and the same thing happened...must i replace all cartridges now?..it seems ridiculous!!!!
    Sergeant:
    Champion:
  • 240 Answers
Long press the power button of your printer..press it atleast 2 min..until it will off and ON it again..
happy fixya..
please rate it ..if it solve the problem...
thnks,
mel
Posted on May 25, 2009
Have Dell 3115cn printer, installed an Innovera cyan cartridge, and the dell keeps saying restart, will not read the cartridge
Probably a chip problem.
Its worth taking the cartridge out (with the printer switched on), close front door, wait for 'Insert C cartridge' message, switch off printer, put new cartridge in, close door, switch on - may clear the problem.
I've seen this before with these cartridges, there was a bad batch of chips around.
If still have your old cartridge, swap the chips over, and try your new toner with the old chip (and for completeess, your old toner with the new chip. If the message changes, the chip that was on the new cartridge is faulty. If it doesn't there's something wrong with the cartridge.
Either way, if there's a cartridge problem, it needs a word with the supplier.
Dec 01, 2009 | Dell 3110cn Laser Printer
Epson DX7450 won't recognise compatible cartridges
This is a common problem and is caused by faulty or missing chips onthe compatible cartridges. You will need to get them replaced otherwise the printer will not operate. Contact the vendor where you bought them from and ask for repalcements or a refund.
Sep 30, 2009 | Office Equipment & Supplies
One of the 3 colors will not print
This problem may be due to blocked nozzles, faulty cartridges or a faulty print head or main board. The first thing to do is eliminate the cartridges. Do a proper cartridge change on both printers, but swap the yellow and cyan (blue) cartridges between printers rather than fit new ones. If either (or both) of the missing colours now appear, you know the problem is the cartridges; replace it (or them) with new ones.
For example, take printer A, with yellow missing. Do a cartridge change procedure on printer A, but instead of fitting a new yellow cartridge, put in the yellow cartridge from printer B (since you know this yellow cartridge works). If yellow now prints in printer A, you know the cartridge you took out is faulty - put a new yellow in printer B, and throw away the cartridge you removed from printer A. Repeat this process for printer B with the Cyan cartridge.
For one or both printers where the above does not solve the problem, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head across fully into its parking position on the right, so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean or two. If the missing colours now start to appear, try another clean or two. If still not perfect, leave for 24 hours and try again. If still nothing, report back.
Feb 08, 2009 | Epson Stylus C62 InkJet Printer
Says to check color cartridge
The cartridge could be faulty. Try replacing it with a new colour cartridge. Are you using generics?
Brian
Jan 11, 2009 | HP PSC 1610 All-In-One InkJet Printer
New Ink Cartridge not working
first check the new cartridge tmake sure you took off the thin clear tape on the bottom of the cartridge. if you did then the cart. is falty and go back to store and exchange. please rate me. thanks
Sep 21, 2008 | HP DeskJet 810c InkJet Printer
Repalcing ink cartridges
Purchase the ink cartridges from a store or www.kodak.com. Open the access panel to where the ink is. Remove the old ink cartridge by pushing up on the bottom tab. Put the new ink cartridge in the slot and push down on the top tab. The ink cartridge should snap. Close the access panel and you should be good to go.
Jun 25, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Replacing ink cartridge
You will need to clean the contacts on the cartridge & the printer.
Also check & clean the interface ribbon ( the white tap connected to the cartridge carriage.
Try this first.
Just a few ques.
Is the cart genuine of compatible,refill?
Did you have a paper jam or power outage before problem?
Dec 06, 2007 | HP DeskJet 5740 InkJet Photo Printer
Print Cartridge Missing
had cartridge refilled put back but comes up no cartridge
May 21, 2007 | Lexmark Optra S 2450 Laser Printer
Printer cartridge
Hi, first things to check are you took the yellow tag off the cartridge when you put it in, or it wont print. 2nd. try doing head cleaning a few times incase the print heads are blocked, 3rd might be just a faulty cartridge.. all the best John
Mar 01, 2007 | Epson Stylus CX3810 All-In-One InkJet...
HP DesignJet 110 Plus InkJet Printer Logo
193 people viewed this question
Seeker5211
Seeker5211
