Question about Kyocera Mita KM-1815 All-In-One Laser Printer
Problem of kyocera
Hi rverybody l have a problem with a photocopy fs1018mfp the problem is error c6400
    New Friend:
    Problem Solver:
  • 7 Answers
C6400 is a psu failure I would do a fuser reset "u163" then try again test the voltage to see if there is power getting to the fuser then you will know to replace the psu or fuser.
Posted on Aug 29, 2013
  • 622 Answers
You probably got hit by a surge... try the best solution on this page...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 24, 2009
How to remove C6400 error in kyocera km 6030
http://www.copytechnet.com/forums/kyocera-mita-copystar/11146-kyocera-km-4050-c6400-error-codes.html
Dec 02, 2016 | Kyocera Office Equipment & Supplies
HOW DO I FIX ERROR C6400 ON MY KYOCERA KM-4050 PHOTOCOPIER
This error could be related to three items:
-power problems
-firmware update needed, like upgrading your computers windows version.
-hardware replacement needed.
First
Try running the copier in another room. You may have a power problem that will be "fixed" by plugging into an outlet in another room. If that works Panamax and Monster Cable make power conditioning products that will allow it to work in another room. Costco even carries one from APC.
APC 1080VA Power Saving Back UPS with 8 Outlets
The second and third option will require a technician from Kyocera.
Oct 01, 2015 | Kyocera Office Equipment & Supplies
How can I fix the error c6400 on kyocera taskalfa 221?
Hi
I found this explanation of your error, although my understanding of it is not entirely clear.
Code: C6400
Description: Zero-cross signal error
Interrupt of the zero-cross signal does not occur more than 1 s.
Causes: Poor contact in the connector terminals.
Defective power source PWB.
Defective engine PWB
You can find this here:
Error Codes Kyocera Mita TASKalfa 221 Code C6400
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | Kyocera Office Equipment & Supplies
I have an error code C6 020 in my copier kyosira KM 1635. Please give me the means of this and what I can do to reslove the problem. Thanks
goto service mode by pressing 10871087. then press 163 then start 4 times.the machine will restart and wola
Jun 03, 2011 | Kyocera Copystar CS-1635 Copier
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
Kyocera FS1118, error code C6400, how do I resolve This?
Hi
Error C6400 appears in Kyocera FS118 when Zero crossing signal problem occurs i.e when the engine PWB doesnt detect the zero crossing signal. This can occur due to --
#1 Poor contact in the connector terminals.
#2 Defective power supply PWB.
#3 Defective engine PWB.
To reset it from Mainatince mode turn the power switch off and open the front cover. Now, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,
C6050, and C6400 are reset.)
4. After this is complete press the back key. The indication for selecting a maintenance item No. appears.
Daniel Scott
Jun 21, 2010 | Kyocera FS-1118 Printer
Kyocera Mita KM-1815 All-In-One Laser Printer Logo
462 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
