Question about Lenovo IBM ThinkCentre® A55 PC Desktop
2 time motheboard change for what resion - Lenovo IBM ThinkCentre® A55 PC Desktop
  • Joe Russell
    Joe Russell May 11, 2010
    whos said it was time to change?
  • 916 Answers
If the computer is working you don;t have to change
However if your sure it needs to be changed there are many reasons it could happen. Most likely is electro static discharge or ESD a static electricity shock from your finger can ruin a pc component if touched.
Posted on May 26, 2009
Changed battery no turn signals or brake light
I HAD THE SAME thing happen to me I blue the to fuse in ihe fuse box under the hood but the resion thay blew was because the wiring for the traler lights had rubed the frame tell thay were shorting out on it check this first befor you chaing the multy switch an all that outher stulf should save you some time an I bleve it is what is going on
Jun 24, 2014 | 1999 Dodge Ram
I have a asus p4p800 se mobo everything works but when i push the power button i get no video. i tried multiple video cards and still nothing
Please Check your motherboard in your motherboard having problem that why its happen please repair motheboard. or Change Motherboard.
May 11, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Date not showing till date
kindly change the cmos battery which is inside in motheboard.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 08, 2010 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Two CDROM be connected in this Motheboard
Yes, this appears to be a standard motherboard with two IDE channels. Two CD-Rom drives can be connected on the same ribbon cable, and with set their jumpers to cable select or one to master and the other to secondary.
Mar 01, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Camera will not turn on. Already replaced batteries.
as per your camment you already replace the battry thats means no problem in battery Ok Firstly please follw the steps,remove memory card(if have),power resourses like AC power adaptor and batteries and wait some some just about 10 min,than reinsert the battrie and AC power adaptor,swith on the camera without memory card,if it is work and than insert ithe memory card otherwise reinsurt the memory card correctly and close the memory card door properly if the camera working fine other wise follw the third instuction that check the AC power supply,this is connect properly through input or not.connect the properly and turn on the camera and check issue is resolved
If you not find the solution thats means your camera has been damaged,need the service of camera and second resion is if you insert the battry incorrectly ,some issue
One more resion is images in memory card,firstly download ths images in system and formate the card.
Thanks,
Jan 16, 2010 | Sony Cyber-Shot DSC-F707 Digital Camera
My 1981 mercedes benz 280se wont start
Fit a new needle and seat assy. Check float is not heavy from absorbed petrol (porous).
Check fuel / float level is correct.
Check operation of automatic choke .
Jun 29, 2009 | 1990 Mercedes-Benz E-Class
About intel 865 motherboard
i have intel 865 motheboard but it's restart or hang after one hour & when it restart automatically getting display problem please help me
Aug 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Air filter change
loosen the clamp at the throttle plate, remove two 10mm bolts from intake resionator, rewove pcv fresh air tube, loosen clamp on resionator to filter housing, remove 10mm bolt at top of filter housing, remove filter housing, open housing remove filter install new filter and reverse process.
Jul 02, 2008 | 2000 Chrysler Grand Voyager
Lenovo IBM ThinkCentre® A55  PC Desktop Logo
251 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
