Question about Nokia 6600 fold Cellular Phone
The phone won't switch on. I put it on charge, then when I disconnected the charger I found that the phone was dead and won't switch on. I've tried removing and replacing the battery and SIM but it's
The phone is dead, it won't switch on
  • paulrina May 26, 2009
    It might have been helpful if the problem was either of those considered in the response. In fact it turned out that the charger was faulty, not the phone, which had simply run out of charge!
    I had tried to check the battery by inserting another but hadn't got one to fit (even though the one I had came from another Nokia - why do they keep changing the design of basic things like batteries?).
  • 10,515 Answers
There might be 2 reasons for the same.
1. An internal Ic might have been blown. In this case, you need to open the cell. Remove the battery. with the help of a Voltmeter, check the voltage across all IC's. The blown IC would be a bulged or seemd to be swelled.Replace that and the problem would be fixed.
Even if you repair it from outside, it would not hurt your pocket.
2. Motherboard - If this is at fault, you might need to pay around half the amount that you spent on cellphone.It's really hard to fix and more likely demands a replacement. The main disadvantage, you cannot use motherboard of some other cell. It has to be a unique one i.e same model.
Note - I am considering that the battery is fine and fully charged. If not sure, swap the battery.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on May 25, 2009
2 Suggested Answers
  • 128 Answers
SOURCE: HTC Hero won't charge. I
U can call your service provider they might be able to help ifthey cant assist you contact the phone manufacture either way you will get ananswer to your problem.
Posted on Sep 01, 2011
Samsung s2 won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 10, 2012 | Cell Phones
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
My phone won't charge, how do I fix this?
To answer on this more info needed.
- When that started?
- Does your phone take charge from another sources (e.g. PC's USB, car charger)
- Is battery dead at all (eg put another battery and try to charge)
Oct 02, 2012 | Cell Phones
NOKIA C7 WONT SWITCH ON HELP!!!!
First Option:
Second Option:
Jul 26, 2012 | Nokia C7 (8 GB) Smartphone
My nokia E5 won't charge, I've tried another charger but still nothing
can you see the pin in the charger socket? these can get bent, other wise looks like your charge socket has come free, from the board
May 16, 2012 | Nokia E5 Cell Phone
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
Hi, i've had my Samsung genio touch for over a year now and i've had no problem untill now, the phone will not charge up, i've tried putting the charger in a different socket and taking the...
a possible battery or charger problem.
check if you can charge using a diff. charger,if you can?then the charger is the problem,replace it.
but if you can charge w/a diff. battery?replace the battery. :)
Sep 09, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
HTC Hero won't charge. I bought a new battery...still won't charge. I've tried a wall charger and a car charger and neither of them work.
Sep 01, 2011 | HTC Hero Smartphone
Sonim xpi jcb toughphone,the phone won't switch on,but when the battery is removed and replaced the phone comes on.However none of the buttons pressed gets a response,can,t enter pin and it won,t turn...
Remove battery,attach and switch on charger,for about 10mins or until charge mode displays,should flash.Insert battery, donot disconnect charger,leave for 2 hours,disconnect charger ,phone should switch on.
Jan 24, 2010 | Sendo Sonim XP1 JCB phone extreme...
Nokia 6600 fold Cellular Phone Logo
206 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
