Question about Numatic Henry Bagged Canister Vacuum
Henry Hoover throwing trip switch in house
The on/off button stopped working on the hoover the other day, I had to keep switching it off at the mains to turn it off. Then yesterday it threw the trip switch in the house.
I
what has happened to it - I'm guessing that the motor has gone in it and will need replaced - if so, any idea of a price and the cheapest place to get one?
Thanks
    Problem Solver:
  • 14 Answers
Sounds more likely to be the switch than the motor, especially if it is the model with the top switch rather than the side "rocker" switch. If you are in the UK, speak to the technical people at www.a1cleaningsupplies.co.uk they can post a replacement. Otherwise outside or even within the UK you can contact the manufacturers technical people. Website is www.numatic.com
Posted on Jun 08, 2009
Nilfisk hoover will not switch on
Start with the basics, check for a reset button on the motor housing, make sure the circuit that the appliance is plugged into not a gfi circuit
thats been tripped. Keep in mind that when working with any electrical
-know your kimits!
Aug 16, 2014 | Nilfisk Vacuums
Hi, My Henry hoover has stopped working about 10
Check the motor brushes as well as the on/off switch.
Sep 20, 2017 | Hoover Vacuums
My Henry Hoover cut out and will not work. Emptied bag and replaced fuse but no success.
If no burning or smelling, maybe nothing to do with motor, and if caused by the safety cut-out, it will need about an hour to cool down, and then check filter, bag, and drop coin through hose, pipes and the floor tool, to check for blockages and to stop it running hot. Damaged cable, worn carbon brushes, broken electrical rewind electrical contacts or even the printed circuit board (later models) are the most likely causes.
Jul 08, 2011 | Hoover Vacuums
My Henry the Hoover has stopped working, I turned it on and it just stopped and there was a horrible smell.,
It sound like you burned it up when the bags fill on these uprites people keep using them the dirt gets in to the motors and burns them out I would say take it to your vacuum repair
Feb 10, 2011 | Hoover Vacuums
My Sebo hoover trips the house mains sockets every time I switch it on, yet doesn't trip the kitchen mains. Have replaced filters/bag to reduce load but still no good. What should I be investigating in the...
It sounds like your vacuum is fine if it works when plugged in the kitchen outlet. It is tripping the breaker switch in the other room because the circuit is overloaded (too many things plugged in this circuit). Try unplugging some things in that room and try your vacuum again.
If it only trips when using one particular outlet, then the outlet should be replaced. I would recommend having an electrician check your wiring out.
Hope this helps
Feb 01, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Henry hoover cuts out
A 5amp fuse will struggle on start up on anything over 1000watts. Check the rating plate on the appliance for total load
Aug 19, 2009 | Numatic Henry Bagged Canister Vacuum
Hetty hoover not working. It was working ok until I opened it up to search the bag for a missing jigsaw piece and I put it all back and I hoovered the mess on the floor, then switched off and switched on...
Know cut off switch, its just not getting power ? 2 things its ether at the wall plug or in side the unit. I have never found a fuse in side them , so it may be just a lose wire did you try other plugs in the house . good luck DFD
Jan 22, 2009 | Henry Numatic "" Canister Vacuum
My hoover mach 5 stopped during use and will now not turn on
If the machine overheats, a breaker trips. Most breakers reset themselves after they cool off. You may have a manual reset button to push on your model. The machine will overheat if the bag is too full, or if the exhaust port is clogged. The reset switch is usually on the back of the motor housing, near the footswitch.
Dec 22, 2008 | Hoover Commercial C1660-900 Bagless...
Numatic Henry Bagged Canister Vacuum Logo
590 people viewed this question
Top Numatic Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
