Home | Lexar | 64MB FLASH MEMORY DRIVE USB 2.0 - (JD... | Pen drive insert dis...
Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -  Hard Drive
Problem for Lexar 64MB FLASH MEMORY DRIVE USB 2.0 - (JDCL064231) Hard...
Pen drive insert disk problem.
By abhinav1501 on May 25, 2009
cant open my pen drive. it says please insert disk. i cant format it ether. i m using vista. and this pen drive does not even show up in computer management. please help.....
Comments:
May 25, 2009
- @ rajan solank .... thanks a lot for your solution but it didnt work.
i did as told but nothing happened.
Best Solution
posted on May 25, 2009
Helpful)
Rajan Solank
Rank: Guru
Rating: 87%, 57 votes
I think there is a virus that has disabled your pen drive please follow these steps to try and remove that disability for the pen drive.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate, and then click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UsbStor
4. In the right pane, double-click Start.
5. In the Value data box, type 3, click Hexadecimal (if it is not already selected), and then click OK.
6. Quit Registry Editor.
Hope you like my solution.
Comments:
May 25, 2009
- Please let me know if you are having this problem with this particular pen drive or all the pen drives that you have. and i will be able to assist you much better.
Thanks.
Have a good day.
May 25, 2009
- Hello, Sorry for double posting but i have got another alternative that you could try out and see if it helps.
Alternative 1:
Change the following from your registry.
Follow the procedure listed below to correct your registry:
1. Open Start >> Run, and type "regedit" (without double quotes), and click OK.
2. Locate UpperFilters registry value. it resides in the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E980-E325-11CE-BFC1-08002BE10318}
3. Click on Edit menu, and select Delete and click OK.
Note: If you receive an error when you try to delete the registry subkey, you may not have correct permissions to edit the subkey.
4. Locate LowerFilters registry value. It resides in the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E967-E325-11CE-BFC1-08002BE10318}
5. Click on Edit menu, and select Delete and click OK.
6. Exit Registry Editor and restart your system.
Alternate 2
1. Click Start, click Run, type compmgmt.msc, and then click OK.
2. In the console tree, click Disk Management. The Disk Management window will appear.
3. On this disk management window, you can see some drives including the portable drive. Right click on your portable drive and click change drive letter and paths.
4. Now a assign a new drive letter which is not being used by any of your drives in My Computer.
5. After assigning the new drive letter your portable drive will show up in my computer with other drives
I hope this solution will fix the problem.
Thanks.
Have a good day.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Lexar 64MB FLASH MEMORY DRIVE
Questions and Unsolved Problems for Lexar 64MB FLASH MEMORY DRIVE
Do you recommend Lexar 64MB FLASH MEMORY DRIVE USB 2.0 - (JDCL064231) Hard Drive?
Answer
Answer
I have a 8 GB transcend pendrive ,was working properly till yesterday evening , now when I connect... (More)
Answer
please help me.. my drive F is not accessible whenever i insert my pendrive
Answer
I have a 2GB and a 4GB Lexar, and I have forgotten how to back-up on it. If I click on the Lexar... (More)
Answer
flash drive with data on it comes up on screen as dane elec then i plug it back in and it changes to... (More)
Answer
Hi. I was wondering if anyone could maybe help me with an 8 gb usb memory stick i have recently... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Lexar 64MB FLASH MEMORY DRIVE...:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14705
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
