Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Troubleshooting for Bissell proheat
Hello I hava a Bissell pro heat 12 amp -it is not shooting out the soap?!!!!
Any suggestions never did this before??!!! :)
  • 9 more comments
  • Anonymous Nov 04, 2007
    my probelm is the same is shooting out the soap from the dispenser.
  • Anonymous May 27, 2008
    puts out water but no solution- bissell proheat 12- fairly new machine
  • tyropermom Jun 18, 2008
    vacuum won't dispense water or soap from bottom or hand held hose never had this problem before its always worked great need to clean carpet new puppy can i say more..i love my bissell kathy fleming
  • Anonymous Aug 02, 2008
    There is no water or soap coming out when the trigger is pressed. However on the small attachment tool the shampoo solution is spraying out of this when the button is pressed. The belt appears to be fine.
  • geneandbarb Aug 06, 2008
    Love my Proheat Pro-Tech but I cannot get it to dispense soap all of a sudden. Help me trouble shoot this problem. Thought may be jammed somewhere but I cannot find where to get the the hose where the soap comes through.
  • motivate4me Aug 16, 2008
    My Bissell will not dispense soap. I thought that since so many other people are having the same problem, a solution would be posted.
  • dshorty6566 Sep 19, 2008
    wont dispense water or soap. Please help
  • Anonymous Sep 21, 2008
    My bissell will not put out soap solution.
  • Anonymous Feb 20, 2009
    Soap is not dispensing. It used to work!
  • PSavino Feb 24, 2009
    I pressed in the release valve lever....nothing. Nor does the RED spinner rotate. Now what? Is the pump part of the heating element?..or where is the pump...because it's not spraying water.
  • rdhager Apr 14, 2009
    i have a bissell proheat 2 and i love it..but now it wont **** up the water ..the hand held tool does,,whats up with this?
  • 48 Answers
Ad small pad to end of handle plunger.. the plunger is not reaching valve inside unit
Posted on Nov 13, 2007
  • 1952 Nov 13, 2007
    this works
  • 1952 Nov 19, 2007
    If this is anew machine ,
    See if the hose attachment dispenses water ,
    If so try taking of the handle look down into the top of the machine ware the handle fits you will see the top of the water release valve, press this in ,if water comes out of the spray tips and the red spinner spins try hadding a thin shim to the bottom of the handle plunger, the handle should then make full contact with the valve.
Take out the water reservoir and check the rubber return gasket
Posted on Oct 19, 2008
Throw the stupid thing in the dumpster,, and rent a machine, then its there problem if something doesn't work
Posted on Sep 04, 2012
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Water and soap coming out wheel area
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fddf
Apr 10, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell pro heat advantage 12 amp
You can download the instruction manual at the Bissell.com web site.
Jun 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Jun 14, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell power shoot carpet cleaner
It sounds like the heater may be plugged. This is a problem for an experienced technician. The heater is located in the handle and they are prone to plugging at the tubing connections. The heater is heating soap and water solution and this can cause the soap to coagulate and plug the lines. It must be addressed carefully to avoid damaging the heater.
Mar 23, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
4,078 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
