Question about Sony Ericsson XPERIA X2 a Cell Phone
Plz help me, this is going to make me crazy! when I try to clean boot my phone with win+O keys, after the alignment it goes directly to normal appearance of the phone and does not install windows files again! what can i do?! also the update service doesn't work for this model anymore!
SOURCE:
SOURCE: Only white screen on my sony ericsion phone k790i
plese,send sony K790i software my email id
Posted on Oct 03, 2008
singh_shady
  • 45 Answers
SOURCE: How would i update my SE z550i's firmware without a USB cable?
hi tech,
firstly: use the seus i.e the sony ericsson update service. its an online free update service by sony. its installation package comes with the phone, ona cd. connect your phone to the pc with the cable and run the soft after installing it. follow the instructions.
secondly: if u want to do it urself, then u ned some third party software like XS++, and some more files known as cust packs, main and fs. the mbn file is not the "firmware" but the "main " of the phone. so its not recommended to "flash" the software at home if u dont have the advanced knowledge about "flashing"... u may brick your phone. (make it permanentally damaged).
u may learn the flashing process from the site: mobilejunkies.net
hope this will help!
Posted on Jan 18, 2009
  • 6 Answers
SOURCE: Phone can not boot completed after restore my m600i's GDFS file to my friend's m600i
hi
you can not flash gdfs from one phone to another doing this will brick phone as all gdfs are different even on same model phone
Posted on Jan 31, 2009
270rexton
  • 782 Answers
SOURCE: i am using samsung gt-s3310 when i try to install
Use Samsung PC Studio.
Posted on Oct 11, 2009
  • 239 Answers
SOURCE: Unable to install applications with.jar ext in S3310
the above method will not be helpfull..
now read this fully..
move to this linkS...
to install games...(.jar and .jad) AND OTHER APPLICATION WITH .JAR
http://3310metro.blogspot.com/
to download games:
http://3310goodies.blogspot.com/
to install themes..
http://samsung3310.tk/
in 3310metro.blogspot.com they explained with screenshots and step by step on how to install .jar file
and one more thing is that u cannot install .jar files alone,the .jad maker is needed and together it needs to be installed..
dont get confused and move to this links,i tried it because i have s3310
if any mail me at ssgodfather@gmail.com
DONT FORGET TO RATE
Posted on Feb 04, 2010
Dell bootmgr is missing
Most likely cause is that the boot order in the BIOS is set up for the HDD first. When turning on the unit, press the key needed to enter setup. Once in setup, search thru the menus for the boot order. Choose the CD drive as the first boot device, then the hard drive as second. Save and exit the setup. When rebooting, ensure the WIN XP CD is in the drive. When the screen says, "press any key to boot from CD", press a key and the WIN XO CD should take over and start the install. Once WIN XP starts installing, follow directions. On each restart after that, DO NOT press the key to boot from CD. WIN XP setup will handle everything until the reinstall is complete. After you are done, you may choose to go back to setup and change the boot order back, but it is not really necessary. The only time you will get the "press and key to boot from CD" message is when there is a bootable CD/DVD installed in the drive. Otherwise, it overlooks it and goes to the next boot device (HDD).
Sep 07, 2014 | Dell Inspiron 2600 Notebook
Dual boot win 7/win 8 acer v3-571 wireless adapter not working in win 8
try a different route go to my computer then system properties then device manager select the wireless adapter and uninstall the driver forget the websites that you downloaded from, right click the wirless adapter and update driver software see it it helps you if not it may be that the dual boot is in conflict
Dec 18, 2012 | Acer Aspire V35716643 15.6inch Laptop...
Hard rest xperia x2
I have screen align problem in my xperia x2 can u help me!!
Oct 02, 2011 | Sony Ericsson XPERIA X2 a Cell Phone
How can i reset my sony ericsson xperia x2
Solution 1:
Just do following with your phone:
Windows key > Settings > System > Clear phone memory
This will hard reset your phone
Solution 2:
There is a boot menu that allows you to do the hard reset (or reset to factory defaults) without using Phone Reset utility.
1. Remove the battery
2. Reinsert the battery, be ready to press two keys on the keyboard
3. Once backlight goes on, within 1 second press and hold win-key (top left) and O.
4. In the menu press W to select clean boot
5. Press Win-key to boot the phone.
Feb 12, 2011 | Sony Ericsson XPERIA X2 a Cell Phone
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
Starts up fine, gets to win xp loading screen and then goes black, i cannot get into windows, plz help
For that when you power up the computer press F8 key then if you are able to see safe mode and other menu then enter in enable vga mode.
Then go to start menu then control panel ->dispaly ->settings.
Also make sure that graphic driver installed and working fine.
change screen resolution to 1024*768 then apply and ok.
then check in normally.
But if you are not able to see even safe mode then you need recovery disk or windows disk.
Boot computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot menu then set first boot device as cd/dvd rom .then save and exit.
Thern it boot with disk.
Then follow the procedure and repair your previous windows.
Let me kno wif you need further assistance.
Nov 10, 2009 | MSI K9MM-V Motherboard
Asus p320 Wont Boot anymore! help :(
Try this
"do hard reset:Press Right Soft Key and tap Reset at the same time, then please first release reset and hold the Right Soft Key, After P320 is powered-on , clean boot prompt picture will show on screen.Currently, you can release Right Soft Key. Follow the dialogue’s message, you can press “SEND key” to start clean boot or press “END key” to cancel clean boot.
Sep 10, 2009 | Dell Axim X50v Pocket PC
"cant install win-xp on CQ-60"
Hello.
Hope this helps...
These are the normal steps on desktop computers but
should work in your case too with a fresh installation
1. Enter bios settings and set CD Drive as first boot device
2. After reboot if you are asked if you want to start on cd chose yes.
3. start Win Xp installation from cd.
4. delete partiton on C; drive
5. create new partition
6. Start installation and format the c:drive
7. Follow the installation instructions,,,
Feb 10, 2009 | Compaq Presario CQ60-220US PC Laptop
Keys stopped working, and can not connect to the network
did you ever get the phone wet at all? i got a few drops of water on my keypad once and the keys started acting crazy like yours...if thats the second phone that youve had like that and its still going crazy...id go with a different phone. some phones just have a defect and always will. but try taking the battery out for a minute...then boot it up and see if it works....but if the phone is defective still....call your service provider and they should be able to send you a new one free of charge if the problem isnt your fault. at&t sent me 3 new ones because i kept having problems with the same phone each time they sent me a new one. crazy phones. hope this helps!
Nov 06, 2008 | Samsung SGH-t629 Cellular Phone
GoTo Problem
Be sure that the telescope is configured for EQ SOUTH mode to tell it is in the southern hemisphere. Once a star alignment is completed NEVER manually move the telescope. Use only the control panel to slew. Everytime the telescope is move by hand, the motors do not know it has been done, and assume it is still pointing at the old direction. Check the manual for setup.
Here: http://www.celestron.com/c3/images/files/downloads/NexStar_SLT_manual.pdf
Apr 06, 2008 | Celestron NexStar 130 SLT (306 x 130mm)...
Sony Ericsson XPERIA X2 a Cell Phone Logo
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
