Question about Ricoh Office Equipment & Supplies
FT4018 RICHO PC MACHINE BREAK DOWN.
WHEN SWITH ON NOICE AND AFTER ONE MINITE TURN OF IT INDICATES E29.PLS HELP
CODE #29 — LENS HOME POSITION ERROR 2
- Definition -
The lens home position sensor’s output remains HIGH (actuated) for 10
seconds after the unit leaves the home position.
- Possible Causes -
· Defective lens home position sensor
· Defective lens drive motor
· Defective main control board
· Defective lens drive mechanism
Posted on May 26, 2009
A bosch varioperfect error code E29
E29 indicates a fill error. If the door is locking then check water feed. Make sure water is on and hose isn't kinked.
Jul 22, 2014 | Bosch Washing Machines
My richo d420 displays functional problem!!! What should i do????? pls. friend help me quickly.
IT'S AUTOMOMATIC JAMED, YOU HAD TO GO SP MODE IN ORDER TO RESET IT. PRESS CANCEL BUTTON, FOLLOW KEY 1, 0,7 THEN PRESS RED BUTTON SIMUTANEOUSLY FOR SEVERAL SECONDS IN ORDER TO ENTER SP MODE.
IN THE SP MODE, YOU SWITCH OFF THE MACHINE THEN LATER SWITCH ON .......WAA LA THE MACHNIE WILL FUNCTION AS NORMAL BUT IF STILL PERSIST , THEN SOMETHING MUST BE CHECKED INSIDE THE MACHINE BY TECNICIAN
Sep 15, 2013 | Ricoh Office Equipment & Supplies
Error e29
Pretty sure that indicates that no water is getting into the machine, could be as simple as a dirty hose filter ( turn off water supply and check filter on inlet hose both ends) or even that the tap is off. Could be the inlet valve or flow sensor faulty. Worst case scenario is a module fault.
Mar 09, 2013 | Bosch Washing Machines
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
My aficio richo 2016 black and white copier is showing code error sc 544. pls how do i fix this problem.
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
May 11, 2011 | Ricoh Aficio 2016 Black and White Copier
Sc990 is error of richo 4545,when turn on this richo after 10-20 mint start the problem
this proplem have many causes follow this steps to dipose of it first check that your drum is good sconde when machine overflow toner and no cleaning in machine due to that and software has many proplem sluggish if yo turn off machine and unpack ram in interface unit and pack again it will disappear temperorly for while and will come back
Mar 24, 2011 | Ricoh Aficio 450 Copier
I have richo fax 1180L , its given error massage (printer error - fuser temparature) i check the fuser its good pls help me to reset this massage
This usually indicates either the heater is not turning on or the fuse for the heater has blown. This is a special fuse at the fuser - it melts at a certain temperature. It usually means the fuser is dirty, needs cleaning or there is a paper stuck in the fuser affecting temperature detection. Fix the heating problem before you waste a fuse.
Mar 30, 2010 | Office Equipment & Supplies
Accuturn 1200 hood switch;
Check the sensor/switch that indicates the Hood is Up, ensure that it is OK. Make sure the Switch/Sensor is being "Activated" by the Hood being lifted,
Feb 05, 2010 | Measuring Tools & Sensors
Richo ft4018 copier copies all black
does the lamp appear to be working take a copy with the lid up!
Aug 01, 2008 | Ricoh Office Equipment & Supplies
67 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
