Technics amp crackle and ''hiss'' noise
I got a 80's technics integrated stereo amp that makes a horrible crackling sound when switched on (even if it's muted) this goes on for at least 20-30 mins not continuously but whith about 30-60 sec of headroom. also when its playing it sometimes makes a small crackle noise. and last i can hear a ''hiss'' sound coming from both treble speakers (2 ch speakers) and i can hear it all the time when the amps turned on doesnt mather if i got a music source etc connected during playback or if its in ''standby'' mode or which channel that are selected. and this ''hiss'' gets louder when i turn up the main vol, and at max its VERY unbearable.
i hope someonne can help!
and is it worth fixing it, or should i go for a another amp?
sorry for my bad eng/ grammar.
  • nospam626 May 25, 2009
    that was what ive been told thanx for confirming, probably the preamp.. the q is is should i get another amp? damn all i want is a clean good sound w/ no crackle/hiss
    that was what ive been told thanx for confirming.. probably the preamp.. the q is should i get anoter amp? damn all i want is a clean good sound w/ no crackle/hiss
I had the same problem. After I changed my alternator, the problem was solved.
Posted on May 15, 2010
In my car when I press the accelerator there is hissing sound,did check the air filter by disconnecting the plumbing but still the sound is present any idea what could be causing this sound.
Posted on Feb 02, 2010
My Technics SUV 660 is making a crackling and popping sound regardless of where the volume is. It does reduce once the amp has been on for an hr or so. Also the speakers are not consistantly on. Any a
If the sound is on both channels then it's probably a device that is connected to both channels. I don't think it's the power supply. I rather suspect it's in the power amp section, since it's not affected by turning up the volume. If the amp uses one of those STK devices as a power amp, it could even be that.
Image of an STK power amp below:
Feb 17, 2014 | Audio Players & Recorders
My su-g95 technics Stereo integrated amplifier wont play any noise. and when i adjust the volume it makes a popping/crackling noise. i am 100% sure all the speakers were hooked up correctly.
Well it sounds like your amplifier IC's are working correctly since you are hearing that pop. I have the same amplifier and every 10db increment it pops. Have you tried every input? Possibly try starting at a low volume, plug an RCA plug into CD or any other input, and touch the center prong of the other end of the cable. You should get a 60hz hum if your in the USA, otherwise it will be 50-55hz. Regardless it should make noise.
Sep 29, 2011 | Technics SUV500 2-Channel Amplifier
Got a crackling sound then it stopped playing.now every time i load a cd i get no disc.
technics wont play cd-r or any copy cd's thats why you get no disc but if this is the case with all cd's then it sounds like you need a new laser unit, the crackling sound is your laser breaking up, there easy to come by on ebay plenty for sale worldwide.
Feb 18, 2011 | Technics RS-TR272 Single Cassette Deck
Technics SU-G95 Amplifier, Intermittent popping/crackling noise
The heat sink has the power modules attached but also has 2 power transistors that become disconnected from the circuit board when the heat sink moves or flexes. The pins on each need to be resoldered (it helps to bend them a bit too, prior to soldering). Had the same problem on the same amp today and that was the fix. There was no sound other than a clicking when the volume control was rotated.
Jun 09, 2009 | Audio Players & Recorders
Technics su-v560 stereo amp crackling
That is a common symptom of not properly grounding of negative side of the output of power amplifier section.Just resolder all component parts joint in power amp.sectiton and double the solder all negative ground.Also clean the pots of all volume controls and selector with a lighter fluid or desame that fluid so whatever sound or crackling noise eliminated and works normal again.. Hope it may help you;;
Jun 08, 2009 | Technics Audio Players & Recorders
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Screaming crackling noise when very hot
Crakling sound is a symptom of loose or cold solder in amplifier section where the STK IC or Darlington transistor is located .You better re solder all parts joints there in order the crackling sound is gone.
Regards;
VOTIT
DON'T FORGET TO RATE;
Jan 08, 2009 | Audio Players & Recorders
Noisy channel of receiver
Generally, crackling noises come from anyplace there is a mechancial connection for the sound signal. The volume control, main/remote speaker switch and possibly the headphone jack. That is where the contacts must be cleaned, but it requires dissassembly. Try operating the main/remote speaker switches, and plug/unplug a headphone several times. I am assuming there is still audio behind that crackling. Are you using both main and remote speakers simultaneously?
Apr 09, 2008 | Audio Players & Recorders
988 people viewed this question
 Grubhead
Grubhead
