Question about Konica Minolta Minolta 7222 Laser Printer Toner Cartridges
What cords do I need to connect konica minolta to laptop
Purchased a konica 7222 without cords. I need to know the type of wires needed for connecting the laptop with printer
  • Konica Minolta Master
  • 6,850 Answers
That a big machine, will only work with xp or before, try computer store
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 03, 2016
SOURCE:
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
  • 18 Answers
SOURCE: Konica Minolta 2500W shows error.
Okay, the driver for the printer (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the printer application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the printer driver, and the problem will be fixed!
Posted on Mar 13, 2009
  • 88 Answers
SOURCE: printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
Posted on May 23, 2009
Konica minolta reset password or what is the Master password
Sir what model depends is it Minolta, Konica, or KonicaMinolta. Want admin PW or service Mode?
Dec 10, 2014 | Konica Minolta 7222 Digital Copier Toner...
Where is the hard drive
check the following link, maybe it will help you:
http://diagramasde.com/diagramas/otros/7145-7222-7228-7235SM.pdf
Usually, the hard disks are located where all the boards are, due to the fact that hdd needs to be connected with this boards and if the wires are longer, interferences might appear.
If you need anything else, just drop us an email at office@bizhubreset.com
Also, please visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 11, 2014 | Konica Minolta Bizhub 7145 Copier
Konica Minolta Bizhub 7222 scaner don't working N-37
Does it print?, Can you ping it. Scan to Email or PC? Or SMB/FTP? Check mail server. also try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Feb 14, 2014 | Konica Minolta Office Equipment & Supplies
Connection cords needed for konica 7222 to laptop
try a computer store
Side note that machine will work with XP or before!!!!!
Jan 07, 2014 | Konica Minolta Minolta 7222 Laser Printer...
Konica monilta 7222 error f-35-4
my machine konica minolta C252 is giving the code 9401 how should I resolve and what is
Jul 19, 2013 | Konica Minolta Minolta 7222 Laser Printer...
How do you change the time on the bizhub 7222?
Enter in the user tools and setting the value.If don`t work tell me for more information.
Oct 01, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7222 f28-3 code
part # for the t/s unit is 40la-2600. if you need it I can order the part for you
Aug 13, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Will the fk-102 fax kit work on konica 7222?
the 102 will work but not all the features will work like with thefk103
Feb 20, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta Minolta 7222 Laser Printer Toner Cartridges Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
