Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Water and clearen not coming out.
The cleaner dose not come out and the little red spinner dose not spin. This starts about 10 minets after I start using it. Help. I need my cleaner to work
  • 4 more comments
  • Teri G Nov 10, 2007
    When I push the trigger on my Powersteamer Pro I can not always get
    the spinner to spin there by not dispensing water or soap. I have the
    1697 model upright.
  • Anonymous Dec 22, 2007
  • MCourt Jan 22, 2008
    Same problem as others... water/solution will not always dispense but does come out of tools. Have cleaned rectangular red lint filter and have taken off clear knob on top of machine base and cleaned the small white plastic filter underneath. How do I tell if it's a bad pump?
  • Anonymous Apr 26, 2008
  • Anonymous May 19, 2008
    Bissel 1698 Pro heater ( carpet cleaner ) Problems ...yes...just cleaned the heater and water now flows. / sprays. Had the pump off and verified that it is working .My main problem is that there is too much water about...flooding everywhere...carpets are quite only solution when trying to vacumn the water up is to empty my water tank completely other wise it still floods out. I have also made sure the trigger on the handle is working properly . I did have the plastic tubing off when I looked at the pump and I am sure ?? I put them back as found. Does any one have the actual diagram of the correct lay out of the tubing just in case I have caused my problems Would appreciate any advice as I have just about lost the plot cheers Barry
  • Anonymous Jul 12, 2008
    will not dispence water
  • 3 Answers
This is a common problem with these cleaners. The solution seems to cyrstalize and black the small tube near the heater. Take apart the handle and the run a small screwdriver or pipe cleaner through to unblock the small tubes, put it back together and it will be like new. I had the same problem with my clearview.
Posted on May 01, 2008
  • 48 Answers
If the modle is an old modle the heater could be blocked,or if it a new modle try taking of the of the handle and ad a small shim to the bottom of the handle plunger to make it a little bit longer ,the plunger might not be reaching the valve,
also unscrew the clear cap which which is on top of the red spinner to see if the white filter under the spinner is clean and free from debris.
when you put the cap back on make sure its not to thigt and the spinner move freely, if the suction is poor make sure the red lint filter in the clean water tank is clean
Posted on Jan 06, 2008
Flow indicator does not spin when the trigger is depressed like nothing is coming through, pump?
Usually that is showing no soap in soap tank even if there is water in the water tank.After filling soap tank make sure it locks in real good ;Thats been my problem a few times.I didnt know the water and soap were in seperate tanks the first 2 times I used mine lol....
Jun 22, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
How do i use my bissell 7920
The 7920 is a great little carpet shampooing vacuum. Look up manual information for detailed assembly and starting/breakdown procedures. Make certain that the carpet/floor has been vacuumed previous to cleaning with the shampooer! The small nozzle opening will get clogged with as little as a toothpick or cheerio! Step on the rear release arm pedal and drop the handle down to the floor, Pull up on the resevoir bucket handle and place the handle of the resevoir back down to open the top of the tank and fill the bladder with hot water. Replace bucket top and place bucket back into vacuum. Raise the handle until it clicks into place. Fill on board soap/shampoo dispenser by lifting out of chamber on unit and fill with appropriate Bissell or upright shanpoo cleaner. Replace unit and make certain the top is tight. Plug unit in and turn on both vaccuum switch and preheat water switch and wait approx. 2 minutes to get water hot enough to proceed with cleaning. Start by rollling cleaner onto carpet and engage trigger approx 2-3' pathway away from you and then release trigger and draw vacuum /shamppoooer back over wetted area, repeat without using water again unless heavier traffic area. Do not over wet area draw unit back and forth a few times until water runs clear thru the front clear window. Proceed to make another path along side cleaned area and so on.
Once you hear the water run out or you have finished cleaning an area then shut of heater and vacuum. release handle with foot pedal release and lift out bucket and pour out dirty water and rinse area/tank /resevoir etc. You should also clean the small red filter in the resevoir of any debris by popping out and replacing. Also, there is an onboard filter under the clear window (where spinner is located) . unscrew clear top , take out spinner device and pull out small plastic screen and rinse or blowout. Clean also the front clear cover if there is debris, by rinsing off with sprayer or wiping clean. You may also find that you have to take off the clear plastic hood window, by unscrewing two screws on either side of nozzle opening (top ) and rinse out as well. Do not, get water under unit into motor area. Place unit upright and in a warm place.. Do not let freeze if in climate that is known to freeze. Good luck cleaning!!
Apr 23, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
The thing that is suppose to spin to show it is working is not spinning.
Are you getting fluid out when you spray? If not, check that you are not out of cleaning fluid or water. Assuming that you are not out of the cleaning fluid, you can remove the cap that holds the spinner and see if something is obstructing it. If you remove the cap and try to spray cleaning fluid, it should come out of the hole. Be careful if you do this as it sprays pretty far (put a towel over the hole where the spinner goes and watch your eyes). If fluid is coming out, it's just the spinner that is hung up. Mine does this sometimes. Good luck!
Mar 10, 2010 | Bissell 1699 ProHeat Clear View Upright...
The spinner wont spin
clog, take bottom apart and clean, keep cleaning it theres more in there
Sep 07, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
The water does not shoot out of my bissell proheat shampooer. The red spinner has stopped spinning.
I'm not sure I have the same kind of machine as you because I don't think I have a red spinner. However, I did have the problem of water not shooting out (although the solution was being used up, just not the water). The problem turned out to be the plug underneath the main tank. To find out if this is your problem, lift out the main tank and take it to the sink. Feel underneath for the plug. Push inside of it. Water should squirt out (assuming there is water in your tank). If it doesn't, turn the tank over, unscrew the plug, and push the thing inside until you get it to spring up and down. If it won't do that, you might need a new one. If it springs, screw it back and try your machine again. Mine worked good as new after I did this. Good luck!
Dec 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell deep cleaner wont release water and cleaner into the flow indicater
do you mean the little red spinning thing?try unscrewing the clear cover , lift the red thing out and check for hair etc.then put it back together. worked for me, hope it helps.
Jul 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
No dispensing of water from container.
Check the bottom of the tank, there should be a gasket on the valve at the bottom of the tank. Must be on the tank and not sitting in the hole. Make sure the tank is sitting firmly and not off set even a little. Loosen the cap for the flow indictor while running, then tight when fluid starts leaking out, stop when the spinner starts spinning. Other then that you may have a clogged line somewhere.
Jul 08, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
400 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
