Question about Garden
Craftsman 32cc Line Trimmer pull start will not engage engine.
I actually have two craftsman line trimmers that you can pull the cord and feel very little resistance and nothing happens. It seems like the clutch will not engage the engine any longer. How can I repair this myself. The first time this occured I took my line trimmer to Sears for a repair. They repaired it but it only lasted three times and then it was back to not engaging again. I have the very same problem with my flymo xlt 3000 multitool
  • Anonymous Mar 20, 2014
    Broken pull cord
  • 376 Answers
With a flashlight, look into the area just in front of the pull rope. You'll see the fins on the flywheel. Turn the flywheel with a small screwdriver until you see a bracket mounted on it. There's is one on each side. While holding the flywheel still with another screwdriver, spray penatrating oil on each one and work them back and forth a few times. You'll feel them loosen up. They are spring loaded and should snap back into place. Hope you can understand this. Good luck.
Posted on May 25, 2009
How to remove clutch drum
In the middle of the drum is usually a small torx screw... I put pull cord rope inside where the plug goes to stop the piston from moving as I'm unscrewing it..
Oct 28, 2015 | Craftsman 25cc Gas Line Trimmer
32cc trimmer stars but wont continue running
Hi donald, if your trimmer is starting but not running it sounds as if the problem is lying with either one of two things. Firstly locate the air filter and make sure it's clean. If it is then the problem is most certainly with the carbrettor. It may need the gaskets replacing to allow the suction from the engine to pull the fuel through.
Aug 31, 2013 | Craftsman 25cc Gas Line Trimmer
The head won,t turn
you will need to pull the head off, as it sounds like the cable is off. there should be four bolts/screws, there maybe some in the middle also, gently remove the head(this is the top of the trimmer where the pull cord is, once you have it separated you can turn the cable by hand and the line feeder should rotate, if it does then look inside the head and make sure it is still square and not rounded. or you can pull the line feeder off and pull the cord and see if the cable rotates, whichever you feel comfortable with trying. Good Luck Tim
May 16, 2011 | Craftsman 25cc Gas Line Trimmer
Hi have a craftsman line trimmer 40cc 4 cycle model 021032 and i can pull the start rope but it won't start. It feels like its supposed to latch on something but it can't. Can it be that the starter pulley...
You can find parts breakdowns for the unit HERE, it also has the part numbers in case you need to order anything. It looks like the starter engages the flywheel directly. I have not taken one of these apart so I cannot give you the best advice.
Mar 27, 2011 | Craftsman 25cc Gas Line Trimmer
Garden Logo
321 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
