Question about Panasonic KX-T7730 Corded Phone
I'm using Panasonic KX-T7730 and I'm having a problem because i can't assign my other line.. the display show CO not assigned.. what will i do with it?
  • Carl Navarro
    Carl Navarro May 11, 2010
    How did you assign it? What model number is the PHONE system?
This is a physicians office and in the past we had to dial nine to get and outside line. Recently we updated to where we have to dial one and then the area code. However since the change our answering service can not get calls after hours because i believe our phones are still programmed to dial nine first. Can you please help us reprogram our phones? Thank you.
Posted on Jun 01, 2009
Hi , i have a problem with my KX-T7730 : in brief , when i press the line access code which is the " 9 key" , it gives me wrong CO . so i want to change the program and set it to my desire CO...
So many options. Why are you dialing "9" for an outside line? You can just press a button assigned to the line you want.
Since a 7730 works on up to 18 different Pana systems, there's no telling what you have, but you can assign a specific line to a button, a group to a button, program the system to not pick vacant lines, or dial the direct line 8x or 8xx access code. There's an outside chance that ARS (automatic route selection) is enabled and the "9" doesn't even give you an outside line in the first place.
Which is yours?
Carl
Aug 28, 2011 | Panasonic KX-T7730 Corded Phone
Line no 4 is always showing co in use
When you press PROGRAM and CO4, what does the display say? A Panasonic TA series system starts with 3 lines. If you're trying to access line 4 and you don't have it, you might get that display, or line 4's button may be assigned to something else. Last, try unplugging the phone system cabinet and plugging it back in. That will reset all calls.
Carl
Jul 30, 2011 | Panasonic KX-T7730 Corded Phone
I have the message CO Not assigned ,How can assig CO? panasonic kx-t7730
Press program button, select button you want to program, dial 0 then dial CO number as in 001 according to which CO line you wish to program. If you are not sure which CO line is missing, check the button programming by the same method. Press program button then any programmable button and it will be identified in the LCD screen. The CO lines may be 2 digit if you have an older system as in 01, 02, etc
Jan 26, 2011 | Panasonic KX-T7730 Corded Phone
Cannot get dial tone on KX-T7730. Intercom feature works fine.
In a TA series system, the lines have to appear on the phone. Press PROGRAM and the CO buttons. Are they assigned? If they are, then you probably have a Class Of Service or Electronic Station Lock issue. Both of them would prevent the phone from getting an outside line.
Carl
Dec 19, 2010 | Panasonic KX-T7730 Corded Phone
My problem was i can not enable the co2 flexible button how to enable and disable the button or assign
I think you unprogrammed a button. Press PROGRAM and the button and read your display. It will either tell you what it is or be blank. To make it a CO button for lines, dial 0 + line number STORE.
Nov 01, 2010 | Panasonic KX-T7730 Corded Phone
Panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
I have a panasonic KX-T7300 and want to assign new speed dial numbers. I have the manual but it doesn't show how to do this please help.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
Oct 01, 2009 | Panasonic KX-T7730 Corded Phone
How to assign one telephone line for 2 sets in parallel? I have Kx T7730
This phone is a system phone. it is intended for use with a PBX, not to be directly connected to a phone line.Do not directly connect or you run the risk of damaging the phone.
Jun 09, 2009 | Panasonic KX-T7730 Corded Phone
LINE NOT ASSIGNED
Since, by default, you have either 4 or 8 lines minimum, do they appear on other phones and is there anything on the buttons? Press PROG and line 3 button. If the display shows CO 003, you have another problem. If they show blank, dial 0 3 and press ENTER. Do the same for line 4 (using 4, of course).
Carl
Oct 24, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
1,447 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
