Question about Minolta DiALTA Di181 Printer
DI181 ERROR C1300
WHEN I TURN ON THE COPIER, APPEAR IN THE SCREEN THE ERROR C1300,I DISCONECT AND CONNECT AGAIN AND THE ERROR APEAR AGAIN. HOW CAN I RESOLVE THE PROBLEM?
  • Minolta Master
  • 6,680 Answers
The motor in side the print head error the print head houses a motor which scans the LASER across the drum, can't get just a motor you get the entire print head try this site if they still have them you have a legacy Minolta machine now Konica Minolta. Open close the front door to reset.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Nov 21, 2015
3 Suggested Answers
SOURCE: Minolta Di181 C1300 Service call
my copier is minolta di 181 it shows c1300 .how can i repair this problme? thank you.
Posted on Jan 05, 2009
jqsababa967
  • 145 Answers
SOURCE: minolta dialta di181 c1300 error
C1301 errors after setting up the Di181.
Solution:
Replace PWB-A, part number 1177-0106-03 for C1301.
Posted on Oct 21, 2008
Qu est que ca vous dire Code C1300
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 21, 2011 | Minolta DiALTA Di181 Printer
Minolta di 181 error code M4
QUEL EST LA SOLUTION POUR DESACTIVER L'ERREUR CODE M4 ?
Jan 21, 2010 | Minolta DiALTA Di181 Printer
Di181 Code C1300 What does this mean? How do I
The PRINT HEAD has failed that is the LASER UNIT in the machine, need a new one
Aug 03, 2009 | Konica Minolta Office Equipment & Supplies
I have error code c1300 on konika 7415, ...help me.
C1300,
C13F0
1. Reset the malfunction.
2. If the malfunction is detected again, check the harness between, and PJ connections
on, the PH Unit and Master Board.
3. If connections are okay, change the PH Unit and Master Board.
Apr 05, 2009 | Konica Minolta Office Equipment & Supplies
Error CO500
On the right side of cotrol panel there is small hole press it with clips .On the screen appear small dot press it then press 3 then apear screen chose from it troble reset .
Mar 30, 2009 | Konica Minolta DiALTA Di200 Copier
Dec 17, 2008 | Minolta DiALTA Di181 Printer
Error c1300
Solution:
could it be this code.
Oct 30, 2008 | Office Equipment & Supplies
Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Oct 29, 2008 | Office Equipment & Supplies
Minolta dialta di181 c1300 error
Solution:
Jul 30, 2008 | Minolta DiALTA Di181 Printer
Scanner Error
hi im jules_09>is there a error code registering at the lcd?what does the error code number so we can see where is the problem coming from,the error code can be reset.try to reset it in the program then see if the problem apears again.
Nov 06, 2007 | HP 610 Color Copier
109 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
