Question about HTC Touch Viva Cell Phone
Programs that used to run on 6.0 do not work on 6.1
I used to have few programs on htc touch which run on wm 6.0 and couple of days back got upgraded to htc viva which runs 6.1, but those programs do not install, or do not run at all. I presume they were created for older versions of wm. Is there a fix or something that can enable them to run on 6.1? Thanks
    President:
  • HTC Master
  • 782 Answers
All wm6.0 apps are compatible with 6.1. Do you have .cab file or exe? if exe you need to use your pc.
Posted on May 30, 2009
I want to change the language of my HTC Touch HD T8282 from Russian to English. WM 6.1 professional OC CE 5.2.20757 (build 20757.1.4.0) SPL- 1.14.0000
You'll need to download a brand new rom for it. Your phone will run Windows Mobile 6.5 perfectly, so it's definitely time to upgrade. You'll need a computer running at least Windows XP, your USB data cable, as well as Windows Mobile Device Center installed to upgrade your rom. Once the software is installed, connect your phone to your USB, and start the .exe file for the rom. Make sure you have a full battery before upgrading your rom, and DO NOT TURN OFF YOUR PHONE even if it looks like it has locked or frozen - it hasn't. The file can be found here. http://www.htc.com/www/supportdownload.aspx?p_id=179&cat=2&dl_id=533 Input your serial number, and select the rom upgrade in the drop down box, make sure your phone is connected and charged, and that WMDC is running, and click the file to start the upgrade. Again, DO NOT TURN OFF YOUR PHONE even if it looks like it has locked or frozen. Leave your phone upgrading for a while, go have a cup of tea. When you get back, you'll have an upgraded operating system, and a phone with English as the language. Any problems or questions, please feel free to reply.
Jul 19, 2011 | HTC Touch HD Smartphone
How to activate gps on my cell htc touch
if you're running windows mobile 6, then you need to update to the newer windows mobile 6.1. this upgrades your gps radio on your system and allows you to use gps. you can find the free upgrade at htc.com. beware, however, that flashing this new rom wipes out your phone. so back everything up with activesync before you upgrade. then go to waze.com and install (for free) their great gps program, then start driving!
Nov 27, 2010 | HTC Touch P3450 Smartphone
Serial Number htc touch p3450
i guess you're trying to download and install the wm 6.1 upgrade for you htc touch. use this serial number : HT831G609985
once done with download, connect your phone to computer and run the downloaded file. make sure that the battery is charged 50% up.
Aug 29, 2010 | HTC Touch P3450 Smartphone
HTC herm200 phone not working properly.. :(
its just the display problem u can just replace the display and it will be done!
Jul 15, 2010 | HTC Cell Phones
Is HTC Touch Viva T2223 upgradable to WM 6.5?
yes it is, but you cannot upgrade it to the new upcoming 7.1
Jan 17, 2010 | HTC Touch Viva Cell Phone
I have htc touch diomond and i want to change my language
First things first, here is a link to a manual for your HTC Touch Diamond
http://x.msmobiles.com/portal/images/htc/HTC-Touch-Diamond-User-Manual.pdf
Apparently you will have to do a ROM upgrade to change the language.
there are forums on the net that cater to this but its experimental at best.
Here is one such forum that has a wm 6.5 upgrade in english but i would use at your own risk,
unless you join the forum and chat up a few of the guys or gals doing the the Rom cooking..
http://forum.xda-developers.com/showthread.php?t=475285
I hope this helps you in your quest for a solution.
If it helps please leave a vote on fixya
May 17, 2009 | HTC Touch Diamond Smartphone
Upgrading from wm 6 to wm 6.1
there is no official rom available for upgrade u have to switch to un official one's at xda developers but it involves risk
Jan 31, 2009 | HTC Touch P3450 Smartphone
HTC Touch HD heating problem.....
dont forget you should be closing off the programs in the top right hand corner (pressing home or changing program doesnt close the program so make sure you are usually only running about 50%) and yes it is normally hot my friend and i both have one and we have already seen that both our hd's are quite hot on the back but not scorching... the bat should take up to 4 hrs most to charge off a wall and with regular txting and small (1-10 min calls) a couple of times a day and a little bti of web browsing the phone bat should last a day least.... (again make sure in setting wifi is off when not using and under settings/connections tab/com manager that this is all turned off (just to make sure)) especially remember that even closing the web browser in top right hand corner can leave 3g running so click on the 3g icon (depending on provider) on the top tab and disconnect it (also save u data usage)) atm im running for about 2 days off a charge at least and all i have done recently is reflashed my rom off the htc web site and whenever not suing the phone put it to sleep using the top power button (one press but im sure u all no).
Hope this helps! :D (great phone when you learn how to work it!)
Jan 22, 2009 | HTC Touch HD Smartphone
Htc touch p3450 is not responding to stylus taps or finger taps
you needto replace the ants which live behind the touch screen
get some fresh once from your garden (or park) if you don't have a garden
Open phone( oh not allowed or warrenty void)
WHAT warrenty?
anywat open phone and you will see a few dead ants behind the screen.
Replace ants with fresh live ones
Close phone (quickly or ants excape)
power on phone
Never do hard reset on phone
It will electrocute some ants
Jan 07, 2009 | HTC Touch P3450 Smartphone
NO Incoming alert/sound on my HTC Touch WM 6.1
In the left side of you htc, it's a sliding button. slide it to the top. this button is used to raise the volume.
Hope this helped!!
Dec 30, 2008 | HTC Touch P3450 Smartphone
HTC Touch Viva Cell Phone Logo
42 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
