Question about Dishwashers
It was blocked and now Error 4 keeps coming up on the screen. how do we fix it???
  • 3,230 Answers
you need to check inside your dishwasher there must be some clog in this.
better if you can provide me the company and the model number of your dishwasher.
post comments.
Thanks
Posted on May 25, 2009
Error 29 message coming up on screen
see the error code and fix it. God bless you
Error 29, Excessive AC Input Current, this mean that some elements inside of the treadmills is consuming more AC currente, like transformer, main motor.
see the block diagram attached.
Nov 28, 2012 | Precor 954i Treadmill Refurbished. 115...
My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Oct 15, 2012 | Siemens Washing Machines
How do i fix my Canon imageRunner 2220i Error Code E000007-0000
The error code E-007 is a fixing film sensor fault, check for paper wrapped around the fixing film, foreign material blocking the film sensor, damage to the fixing film, fixing film sensor failure, or DC controller PCB failure.
you might be able to try and reset the code in service mode by hitting
the additional functions button 2&8 at the same time then the addit funct button again.. you might have to keep trying to reset the machine on and off till you are able to get in
once in service mode you hit the copier tab
then you goto the functions tab its in the middle of the screen across the top
then you will click on clear button
then the very first item on the next menu should be ERR
high light that and then click the ok button on the bottom of the screen a couple times then turn the copier on and off. hopefully the copier will come back up if it doen't then there is a problem with the fixing film and it will have to be checked out
Jun 22, 2010 | Canon imageRUNNER 2220i Grayscale Copier
Lens error lens wont close what to do?
Hi,The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Here are different solutions to this problem;
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra power to help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). Some people also have actually used a "Shop Vac" with this fix to help extend a retracted lens.
Thanks and take care
Apr 25, 2010 | Nikon COOLPIX L18 Digital Camera
I have an LG wall unit in my sun room. Geicos are coming into the room through the unit. Do you have a screen I can use to keep the Geicos out??
At a hardware store ask for 1/4"bird screen to fashon a cover.It wont block air flow that the unit needs & keep the pests out.
Mar 18, 2010 | Heating & Cooling
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Kenmore Elite quiet pak 4
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Panasonic dvd player, wont play error code HO3 keeps coming up, took it back to shop they wont help as cant find receipt
On my DVD-LV50, I was able to re-initialize and fix a different error (error code H05). It might work for you, too.
With no disk in the player, press and hold these buttons for 4 seconds:
  1. Back skip -- [ |<< ]
  2. Pause -- [ || ]
  3. Play -- [ > ]
The screen will go blank, then say "Initialized."
After that, it worked like new.
I hope that helps.
Oct 17, 2008 | Panasonic DVD-LV50 Portable DVD Player...
Phone keeps turning on and off (had gotten multiple errors)
my blackberry 7100t was dropped and now the problem is its screen keeps on fading off and colours keep on changing again and again..the screen comes nack to normal if the screen backlight is switched off for around 5 min..it will work normally for sometime may be for ten fifteen min and the problem starts again..suggest some solution for this..and also if u could advice me from where i could get a new battery for the same phone..
contact:
madhur@priest.com
May 12, 2008 | RIM BlackBerry 7100t
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
