Question about AKG C419L Professional Microphone
Excessive line crackling noise
Plug the AKG C 419 PP into XLR socket on desk and line is crackling.. Seems to be possibly the wiring inside the articulated arm of the mike. Touching the end of teh mike doesn't crackle, just when touching/moving the arm..
    President:
  • 1,137 Answers
The service manual is at www.akg.com/mediendatenbank2/psfile/datei/19/C4194055d1fa264a7.pdf. You will have to replace the wiring that goes to the cartridge through the gooseneck.
Posted on May 26, 2009
AKG 120 to Tascam US-800 connection issues
There is no reason to use such a configuration with the US-800. I advise using a standard XLR mic cable. It's likely phantom power doesn't work over the 1/4" jacks.
Jan 26, 2012 | AKG Perception 120 Microphone
How can you open an AKG 220 perception mic to repair it? the mic got knocked over and still works, but the inside seems loose, moving around from side to side.
at the bottom of the mic where the xlr connector is you'll find a ring screw with two notches. unscrew this and you con remove the lower housing. The upper housing is hold by 5 screws.
May 13, 2010 | AKG Perception 220 Professional Microphone
Is there a spiecal jack plug for a microphone. stupidly cut old plug off and threw it away without looking at the wiring
You can actually wire it up with any type of connection you need. The most common are a ts (tip sleeve) 3.5mm Jack; a 6.35mm 1/4 inch Jack or an XLR connection.
It just depends on what you're plugging into.
Hope this helps
Mar 01, 2010 | AKG D770 Professional Microphone
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
Creates excessive noise with no signal
Could you swap with a different mic so you could be sure if the line/cable are allright or confirm that the mic is defective... Also when repairing a mic, 90% of problems come from the connector welds. Use a small flat glasses screwdriver and have a look at the weld of the xlr connector from the inside...
Oct 07, 2009 | AKG Perception 200 Microphone
Akg D8000S
need to buy the proper sound card ,or a mixing board built for your comp.thier is a usb cord out there,i have one with 1/4 inch on end and usb other end,im sure someone makes one with xlr.
Jan 30, 2009 | AKG C451B Professional Microphone
AKG Model C451 EB Microphone.
I drilled a tiny hole (.038") through the outer shell and the cartdrige where the body of the XLR connector is mounted and screwed a tiny screw into it from a pair of old glasses.
Sep 29, 2008 | AKG (WMS40DIV444US54) Microphone
Lots of white noise and crackles, and intermittent problems.
check and make sure on the back of the power supply that it is set up for your local voltage(120/240)
Sep 06, 2008 | AKG SolidTube Professional Microphone
Crackling
either you have a short in the wire of your earphones or were the female plug is in the player needs to be soldered inside the player
Feb 09, 2008 | SanDisk Sansa e250 MP3 Player
AKG C419L Professional Microphone Logo
296 people viewed this question
Top AKG Audio Players & Recorders Experts
Vito Vacirca Jr.
Ben Armstrong
Edward Carrington...
Level 1 Expert
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
