Question about Acer AL1912 19" LCD Monitor
Acer 1912 monitor that ceased to function
One day when I turned the power on to my monitor it flickered and then went black.  The little indicator light on the front of the panel went black.  I made sure there was power at the plug and at the 3-prong input. Then I took the back off and the metal shield over the two circuit boards.  I inspected the power board for obvious burned components. Found none on the top surface.  I then plugged in the power and what I heard was a constant clicking sound like a relay trying to latch but failing. With a plastic tube in my ear as a stethescope I located the click as being somewhere in the large transformer, part # DG100017200 LSE  0442.  Has any one had this same experience? I do not believe the monitor made any sounds when it was working properly.  Any suggestions.
Aaron
  • 1 more comment
  • aaronsara Oct 23, 2007
    STP162:
    Thanks for the comments. I agree it is a less than premium monitor. However, spending an hour or two of my time and a few parts is well worth it to get it operational.  I am quite good with an ohm meter and following circuits and with a soldering iron. However, I do not know how to test capacitors. Particularly ones stilled attached to the pcb.  Any suggestions.  Thank you.
    Aaron
  • Anonymous Jun 14, 2008
    exactly the same
  • oestby Sep 12, 2008
    The screen went black, no leds are shining. The yellow transformator at the power supply sercuit-board is making a just hearable clicking sound approximately every second.
My monitor started to flash for 3 or four minutes before starting up, this was after three good years of faultless service. (I've always found Acer monotors to be excellent value) I was just about to purchase a pair of new monitors online when I decided to take it apart, as I had nothing to lose. I found that 2 capacitors on the mainboard had bulged and leaked. A quick trip to Maplins and 79 pence later I was armed with 2 new 1000uf 16v capacitors and within five minutes had removed and replaced the damaged items. I now have my good old AL1912 back in service.
Posted on Jul 08, 2008
    Scholar:
  • 132 Answers
Yes, its what happens with crappy monitors ,sorry to say.  I had 2 CTX monitors in, both similar -- no power. After 2 hrs of pulling my hair out to find the problem came up with two capacitors that went out (on the power board). Got them unsoildered and replaced them with common ones.  One worked longer than the other, both people eventually tossed them and got a better quality product.WARNING: I don't know your background but remember, capacitors hold their charge even after the item has been disconnected from power...be careful.
Posted on Oct 22, 2007
  • Sandy Chamberlain
    Sandy Chamberlain Oct 23, 2007
    In that case ...try this link
    http://www.repairfaq.org/sam/captest.htm
    best of luck!
My acer monitor began to flicker for several hours and then it just went black. I bought it on February 27, 2008 from Consul Tech Computers in Kelowna, BC. and he is no longer in business. I would like...
Flickering monitor display (assuming graphics card and vGA cables are ok), are indicative of either a failing powerboard capacitor, a "dry joint" or other internal failures. I would also suspect the inverter as a prime cause here. Repairing... probably beyond the cost of a new monitor. As to any warranty with the original supplier, i'm in the UK so cannot advise what to do there. TBH: 3 years from a monitor is about the life span depending on how much use it gets
Jan 08, 2011 | Acer X193W LCD Monitor
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Screen black and drive not running. No lights except ON which didn't turn off. Removed bat...went off. Replaced bat and only Power light came on.
Have you checked the Function Key combinations that switch your display to an external monitor, from the laptop's monitor?
May 21, 2009 | Acer Aspire One Netbook 8.9" Notebook
INPUT NOT SUPPORTED
Is this on a Linux pc? I had this problem with a Viewsonic and Ubuntu. I had to play with the Horizontal Sync and Vertical Refresh till I got it right.
Aug 18, 2008 | Acer AL1916W 19" LCD Monitor
Acer 5610
If you get the windows splash screen and it goes black that would be an indicator that your backlight is bad. Try to hookup an external Monitor to determine this. Otherwise if you get no image at all even when you connect an external monitor. You need a new HD and must relaoad your OS, and all programs! Let me know!
Nov 26, 2007 | Acer Aspire 5610-4648 Notebook
Acer AL1912 19" LCD Monitor Logo
509 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
