Question about ASUS P4S800-MX Motherboard
No screen image
My computer turns on everything works fine execpt there is no image on the montior and its pluged in fine and then the computer starts to beep it goes on for 20 min the shuts itself down
  • 700 Answers
You gonna need an spare monitor, video card and a memory card. But first have the RAM card and the video card(if plug in) be clean or reseat. Use clean soft eraser to clean its edge connector, both side. And check your video card for dirt or stock fan if it have. Do this cleaning when unit is off and unplugged to wall socket even UPS. Also reseat the monitor cable. Then try to power it up again.
Next step;
And since it beeps it seems one component is failing or loosing its contact with the board. Then use the spare ram, then the spare card, if still not viewing any try to swap the monitor.
Or if you have no spare if cleaning only doesn't help, its practical to bring it to the expert.
Posted on May 25, 2009
I own a Westinghouse L1975NW, Power light Green, Image on screen just very dark, It fit the bill for the common backlight issues that this monitor seems to have. So I did the repairs, (Bought the kit-...
Did you recheck the MOSFETs? You will need a set of test lamps to test the inverter to see if it is the inverter or the lamp assemblies. I am surprised that the kit only contains 2 caps, it should have at least 4 caps, 2 each for the 5v and the 18vdc power supply section. Take the DC reading on the caps to see what you have, take the reading WITHOUT turn on the monitor (the power supply is running al the time), then turn on the montior to see if it maintains the output voltages.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 05, 2011 | Westinghouse L1975NW Monitor
Me and my friend are takig turns using my other friends ipod and my friend forgot the passcode and tried to much, and nw it says connect to itunes. when we do it doesnt work and so we tried everything, we...
With the phone UN-PLUGED and powered OFF. Hold the home button and plug into a computer using I-tunes. Continue to hold till the restore screen starts on the computer. You will restore the device to factory and loose everything but it will be useable.
Feb 24, 2011 | Apple iPod touch
Montior screen is half shaded and half bright
Do this to check if your monitor is in working state or not...!
Step 1:- Turn on your computer.
Step 2:- Unplug the Video Cable of your monitor which is connected with the computer.
( Video cable:- Cable going from the back of your monitor to the back of your tower. It has a plug with two screws on the plug ends, which you can unscrew to unplug it. Thats how it looks like. Some times it is in grey in color some times in blue.)
Step 3:- Now check on your monitor. If the display says " No Input Signal " :- your monitor is fine. Some thing wrong with the computer graphics.
If there is not display and the monitor light is blinking or solid the monitor has gone bad.
( Note :- Remember when you unplug the video cable do not unplug the power cable of the monitor. )
Let me know if it helps.
May 18, 2010 | Computers & Internet
I have no picture on my flat screen montior im using a older montior and its works
If the monitor light comes on but you get an "out of range" message, you'll have to start the computer in "VGA mode". Probably your video card is set to a resolution that the monitor won't display.
Just a thought, as you didn't say anything but you don't have a picture.
If this doesn't work, check the power and cord and video cable before you declare it dead.
Nov 11, 2009 | Computers & Internet
LCD montior not on to see picture before taking picture
On the EVOLT E-300 it is not a camera that has a live view LCD screen that will allow you to see the image before it is taken. You must take the image with viewfinder only and only use the LCD screen for review purposes. This is how the camera was designed.
Mar 15, 2009 | Olympus EVOLT E-300 (Double Lens Kit)...
Montiors shut off
if the monitor goes into standbye when you plug it into the computer , it generally means there is NO signal coming from your video adaptor.
Plug the old monitor in , if it works, ide suspect the new monitor(s) are not working correctly.
if it doesnt work , you need to restart the computer in safe mode by repettitively tapping the f8 button as the computer starts, before it says "starting windows".
If you have a signal on your monitor in safe mode, then most likely you have a bad or corrupted video driver and it will need to be updated.
if you have no video in safe mode , you will need to remove the cover and physiclly check that all add-in card power cables and memory chips are squarly seatied in there slots. MAKE SURE YOU UNPLUG THE COMPUTER AND DISCHARGE ANY STAIC BUILDUP IN YOURSELF BY GROUNDING (TOUCHING) SOMETHING METAL BEFORE YOU TOUCH ANYTHING INSIDE THE COMPUTER.
AFTER YOU CHECK THESE THINGS AND TRECONNECT THE POWER AND TRY TO START......POST AGAIN HERE
Feb 18, 2009 | Systemax Venture PC Desktop
My Camera stoped recharging for no apparent reason.
Please contact Jazz at 732-572-7050 for customer support.
Thanks,
SHeryl
Jazz Products, LLC
Nov 30, 2008 | Jazz DV-179 Digital Camera
Astar flat screen monitor
i need help getting my astar flat screen tv to power on. the blue light is on in the center of the tv
Dec 24, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
The montior shuts off and on
If it is doing this during normal use, try using the little control buttons on the monitor itself to navigate through its configuration menu and try to find anything about screen savers, power saving, shut down, anything like this, and disable it all. And set everything else to AUTO if available. :>)
Nov 13, 2007 | Samsung SyncMaster 930B 19" LCD Flat Panel...
ASUS P4S800-MX Motherboard Logo
97 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
