Want to know front panel audio connection - Computers & Internet
  • 159 Answers
It works in the same way as the behaind ones
Posted on May 25, 2009
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
I want to know where the connection points are on the motherboard for the front mic and audio jacks. I have a epox ep-5pdaj motherboard. Will you send me a diagram please.
close to the back panel of the mainboard, below the back i/o connectors and 3.5mm audio jacks.
You need to remove the two jumpers from the pins, this is where you connect the front panel audio connector, if your case has each wire separate. then please look at this webpage http://www.intel.com/support/motherboards/desktop/sb/cs-015851.htm look at the part "For AC97 Front Panel Audio" PIN 1 should read MIC. If not, then scroll down, you are reading the wrong part of the page.
Aug 07, 2010 | EPoX EP-5PDAJ Motherboard
I cant listen to the sound in front panel
Probably as simple as the front panel is not connected.
Be sure the front panel cables are connected to the correct audio output connector/pins on the MB.
http://www.asrock.com/support/index.asp and get the manual
for the board so you know where and how they should be connected.
Jul 12, 2010 | Asrock G31M-S Motherboard
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
Jul 10, 2009 | ASUS Computers & Internet
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
ASUS p5kc front panel connector
all motherboard front side audio connector is equal so if you compair with onther motherboard
connector
Feb 02, 2009 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Asus p5pe-vm front panel audio connector (10-1 pin FP_audio)
Look this picture below, this is ASUS P4VM front panel.
Hpe its solve your problem....
Nov 26, 2008 | ASUS P4S533 Motherboard
Plug mic and earphone to the front panel
hi!gud am...hope this will help...
have you check if your audio controller is working?have you installed the driver?if not check this out...start>control panel>system>hardware>device manager>sound,video and audio controllers...
is your mic and earphone new?if not try to replace it with a new one maybe its broken that's why its not working...
check if the front panel audio is connected on your mobo...some casing with front panel audio has no connection...let me know what you see and tried ok?
goodluck...
Feb 28, 2008 | EPoX EP-4PLAI Motherboard
Front sound and mic pins
Hi, The motherboard connection points to the front panel audio jacks are shown in the diagram below. It was cropped from a page of the user's manual. A downloadable version of the English version of the User's manual is at http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5RD1-VM/e2440_p5rd1-vm.pdf Hope this be of help to you. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 05, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
