Question about LG KU990 Viewty
I'm stuck on the yellow screen thats says "refreshing"
I need to reflash my lg viewty but how?
    Sniper:
  • 65 Answers
This could be a software or a hardware fault. If you recently changed the firmware or made other modifications to the file-system using EFS Explorer (or similar software), it may well be software related.
If you think the problem may be software related, try using Emergency Download mode to reflash your phone.
Possible faults to check with the hardware include:
  • The battery is empty, damaged or worn out. Try taking the battery out and connection your phone using the USB cable only.
  • The contacts of the battery are damaged or the battery has leaked.
  • The screen may be damaged and will not display a picture - check if the lower buttons light up when the End Call (Red) key is pressed.
In the case of a hardware fault or if you are unsure, contact the store from where your purchased your phone on for advice on the best action to take.
Emergency Download Mode __________________________________________ What is Emergency Download Mode? Emergency Download Mode allows you to connect your phone to your computer and use flashing tools (e.g. LGDMP) to restore or change your firmware.
_________________________________________________________
How do I access Emergency Download Mode?
  1. Make sure your phone is off.
  2. Hold down the Green (Call) + C (Delete) + Red (End Call) + Image Stabiliser (Lock) buttons
  3. Your phone should turn on and go straight to a screen saying 'Emergency Download' without first showing the usual LG Logo.
  4. You can now connect your phone using the USB cable and use Flashing tools to fix your phone.
_____________________________________________________________
Use the EFS explorer mode and check the maps.
If there is a map named TOTO and a map LGAPP.
First rename the map LGAPP in to any name you want or change
it like this AAAA.
Secend Rename the map TOTO to LGAPP.
Delete the first map you renamed the LGAPP.
When your finished choose disconnect and wait until the process is done.
You will see the phone starts up in a normal mode if not then
you've to reflash the phone.
I hope this will helps.
Posted on May 28, 2009
Yellow screen
Hi, once you have a yellow screen on your LG Viewty phone which is a vert common problem, the you have to reflash the phone with the correct firmware. You need to get a tech that has the software to help out...
Hope it helps...
Jul 01, 2011 | LG KU990 Viewty
My LG Viewty has a yellow screen and says refreshing
if you want to fix it take the battery out? but what about the yellow screen ?
Jan 03, 2010 | LG KU990 Viewty
Yellow refreshing screen problem
You can better visit me and see the results of my solution.
There is one of them it can fix your problem and I am sure you
will find the answer!
Take a look at:
http://www.fixya.com/support/t1793053-lg_ku990_yellow_sreen
You'll fix your phone be patience and fallow the instructions!
Best regards:
Henk®Muskita© 2009.
Jul 18, 2009 | LG KU990 Viewty
Yellow refreshing screenon lg viewty what is this and how can i get my phone working again
Look at this issue: My lg ku990 has yellow sreen.
Answer:
I am sure this will fix your yellow screen that coms up on the start.
Read and take a lot of patience when you do the job.
I am sure thhis will help you out!
Best regard:
Henk®Muskita© 2009.
I can't connect my lg viewty with the refreshing problem to my pc
please try to connect your lg to some some another pc, perhaps it will work, keep it up
Jul 13, 2009 | LG KU990 Viewty
Lg viewty yellow refreshing screen
you need to reflash it , you can either take it to a mobile repair shop or attemt to find the firmware yourself
Jun 01, 2009 | LG KU990 Viewty
Start up screen/Shut down screen
Even thought your phone is unlocked from virgin the software is still a virgin viewity software. your can try and press on the arrows <<<<>>>>> at the bottom of the screen when the come up this will allow you to remove the network label but not on startup that requres a mobile shop to reflash the phone with generic software which will cost up to £25 shop around
May 27, 2009 | LG KU990 Viewty
My phone KU990 was in the middle of backuping and the usb cable accdently fell off and the yellow screen appeared with the text refreshing... i tried pressing it, taking out the battery and connecting to...
sounds like you need to reflash your phone back to it's original settings.
you'll need the following:-
LGMDP software - this allows you to flash the phones internal file system
'your specific network firmware'.DZ - this is lg's own firmware with the network settings in a .DZ file.
if you go to http://www.mygreatphone.com/forum/modifications-hacking/12356-ref-rollup-firmware-backups-hacks.html#post91633 all the info you need is in there. i could tell you all about it here but i'd just be repeating what's in the forum.
don't worry, it can be sorted
<JAIMO>
May 12, 2009 | LG KU990 Viewty
Yellow screen
Dude that's simple but you need to have the sofware back up to reflash your phone in other words reinstall the whole system back on the phone. But how come you don't have a back up since you said that you got a yellow screen bc you were making a back up. Anyways, I did the same thing to hack my Viwety and I had no problems, but since i cannot fix it for you I can only point you in the right direction... go here for more information http://www.mygreatphone.com/forum/modifications-hacking/1543-firmware-flash-bricked-handsets-v10a-only-no-noobs.html
Do a little research and you'll find what you need here
Aug 06, 2008 | LG KU990 Viewty
LG KU990 Viewty Logo
1,275 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
