Question about Philips 42PF9630A 42 in. Plasma Television
No colour and picture freezing on philips 42fd9953/69c philips tv
Hi having problems with Plasma tv can you help
Thanks
Elaine
  • Yannick Verhoog May 11, 2010
    Sure I can help, but you'll have to ell mewhat the problem is...
    ANd the type of television would be nice too.
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
SOURCE: LG plasma tv
Most likely it's the PDP panel wires failure. It won't cost you more to repair then to buy a new one.
Posted on Apr 28, 2008
SOURCE: LG PLASMA TV WITH COLOURED LINES OVER SCREEN
I have the exact same problem with my 42" LG plasma which is about 3 yrs old. Turned it on one morning and had verticle lines all over it with only the sound playing.
Posted on Jul 07, 2008
  • 223 Answers
SOURCE: Samsung PS42C91H plasma tv
I think you have a fault on the line output stage either dry solder joints or a fault with components on the line output stage or a faulty line output transformer. If you can check this for yourself otherwise find a competant technician. Hope this helps.
Posted on Oct 04, 2008
SOURCE: Philips Plasma NO LIFE
I had the same problem (with 42FD9954/17S) that when turned on the unit, the green LED turned off and came back to red again some time later. I kept turning it on and once it went to a clicking relay sound and blinking green LED with it. It did that for a while and stayed turned on. I noticed that it is temperature sensitive. Colder the room is more often does it. Used a hair dryer and blown hot air into the unit at the left bottom grills. It helped and started to tun on quicker. Later it has deteriorated so bad that I took it a part and after several ice spraying test showed that on the middle big board (power board) there was an electrolyte condenser went bad. It is the one one which is at the middle, bottom center of the board near the fixing screw. There are two of them (cylindrical objects). The left one was the culprit. However when I fixed it, it turns on immediately but goes blinking red after that. Phillips say it is a static discharge problem. I might blown something when soldering the parts. I don't know what. Any ideas?
Posted on Feb 08, 2009
Red colour picture on plasma TV
It might need the color to reclibrated, if that does not work, a gamma electronic board need to be replaced
Jan 06, 2010 | Samsung PS42C91HDX 42 in. Plasma TV
2003 philips 50" plasma tv with picture fading. How do I fix this?
Hi,my philips plasma 50FD9934 dont turn on just led flasing red and green contniusly.Please help!!!!This is a power suply problem?thanks
Nov 14, 2009 | Philips 50FD9934 50 in. Plasma Television
No picture in Philips 42pf7220a/37 Plasma TV.
Hi my name is Roety,
I can help you with your issue ,
You can look for two bad capacitors on the power supply. They will look swollen on top like this photo
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Nov 14, 2009 | Philips 42PF7220A 42 in. Plasma Television
Hi. I have a philips plasma (50PF7521D). How do i adjust the colours seperatley (red too high, green too low)? Thanks.
You have to adjust the colors in the menu manually. It can be done but look at the manual online if you need help finding where in the tv menu the color adjustments are located. Best of luck and yes, you can adjust them manually and not use a preset scheme.
Jul 20, 2009 | Philips 50PFP5332D 50 in. Plasma...
Colour misalignment and focus
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
Need settings because of rubbish picture
There is no right or wrong setting for the TV, but I find the following give about the best results:
  • Contrast - 65 maximum
  • Sharpness - 2 maximum
If these are set any higher, the picture becomes very grainy, particularly around defined shapes.
  • Contrast + - OFF
  • NR - ON (If applicable)
These settings will need to be changed for each of the following:
HDMI 1& 2
  • EXT 1, 2 & 3
  • Analogue tuner
  • Digital tuner
The problem you describe, is usually with a satellite or cable box.
Unfortunately, there's nothing much you can do about the dead pixels, but the settings may make them less obvious.
May 01, 2008 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Colour problems
try to go in menu do factory reset ok
Feb 03, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Colour distorting
Sounds to me like your digital board is bad.
May 13, 2007 | JVC GD-V4211PCE 42 in. Plasma Television
Philips 42PF9630A 42 in. Plasma Television Logo
185 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
