Question about Panasonic NN-S592 Microwave Oven
Microwave Oven shuts off after 5 seconds
Problem exists under all modes/cycles. Tried unpluging and re-plugging into another wall socket Microwave Oven shuts off after 5 seconds, have reset - tried other outlets, etc
  • 3 Answers
What type of microwave is it (make and model)?
Posted on May 25, 2009
One day the microwave just showed PF on the screen, unplugged and plugged in tried to use it, worked for 30 seconds, stopped and showed PF again. Any ideas? It is only a few years old and used in our...
PF is Power Failure. Check and see if the Oven has a reset switch or power button. Try and hook up an extension cord, plug one end into a usable output (wall plate) and the other into the 110VA line plug attached to the Oven. Turn on....if it works then the problem is a circuit breaker or wall interface. If it fails with the extension, then it is an electrical problem with the microwave device itself. If there are no Reset features on the oven, an internal fuse may blow, or other shorts are occurring. The cost to fix is more than a new unit. Lowes has them as low as $150.00.
Dec 18, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Touch screen displays is lit up , but will not respond by touching any of the promts. I have unpluged the unit hopeing to reset no change. unit was working fine the day before.
HELLO.
The solution is to troubleshoot the microwave as explained below.
1 Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
2 Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
3 Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
4 Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
5 Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
please let me know the outcome..
thanks.
Sep 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Stuck in demo mode on GE jvm1850 microwave tried unplugging, tried power level and zero at same time, tried holding clear, holding help, tried everything i have read so far but they seem to all be for...
A hard reset would be the first thing I'd recommend, but unplug it for about 2 minutes, plug it back in, and watch to see what it does.
Wait at least 60 seconds after powering it up to see if an "F3" code comes up.
You can download GE owner's manuals and installation instructions here. See what it says about a demo mode.
Otherwise, I would suspect a shorting keypad.
If you need more help, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 05, 2010 | GE JVM1850 1000 Watts Microwave Oven
Kitchenaids microwave error message F2.Q1. What to
F2.Q1 Not reading keypad
inputs
1. Unplug microwave oven or disconnect power.
2. Replace the user interface board (UIB).
3. Replace the door control assembly.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
Many of the error codes may be solved by power cycling: unplug microwave oven or
disconnect power. After one minute, plug in microwave oven or reconnect power.
i found this info on a tech sheet hope this helps, let me know how it goes... some of those electronics had 5 year parts warranty i would check that out....Also u might be better of buying a new one if its out of warranrty as some of those boards are expensive, obvioulsy unplug unit first try to reset it self.
Feb 14, 2010 | KitchenAid KHMS2050SSS Microwave Oven
GE Microwave DEMO MODE
The owner's manual (which can be downloaded here) doesn't show any demo mode, but it may exist.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Oct 06, 2008 | GE JE1590 Convection / Microwave Oven
Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
Turn off Demo Mode on goldstar Microwave
Otherwise, try holding CLEAR for 3 seconds, then try each pad for 3 seconds.
Sep 07, 2008 | Goldstar MV-1615 Microwave Oven
Trouble shoot microwave
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Also, are any other of your electrical items (light bulbs, DVDs, etc.) failing lately? This could indicate improper power line voltage.
Let us know if the hard reset doesn't fix it.
Jul 18, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Timer Shuts off after 5 seconds
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | GE JES1289SK Microwave Oven
Panasonic NN-S592 Microwave Oven Logo
634 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
