Question about Dishwashers
Replace a dishwasher
We need to replace an old leaky undercounter dishwasher, ut the water supply hose is plastic.  Will this become a problem when we purchase a new one and try to install it ourselves?
  • 94 Answers
Hopefully there's enough slack in your water supply hose for you to just pull out the machine and unscrew the hose.  Be sure to turn off the water before you unscrew it.  You might be able to unscrew the bottom plates to access the supply connection from the front.  Your new machine will probably have a 3/8" female connection.  I'd suggest having a 3/8" street elbow and an adapter for 3/8" male to whatever your plastic pipe.  The other thing to watch for is whether your machine is hardwired for electricity or has a cord and plug.  You can use your old cord and plug on the new machine, if the new one doesn't have one.
prem
Posted on Oct 21, 2007
How do i fix leaky dishwasher?
Hello Gus Is the leak from the drain hose or water supply or neither
of those ? Is it leaking from the door ? I have had success with
RepairClinic fixing appliances in our home. We have a Kenmore
Dishwasher but I haven't had any problems with it. If you have to remove your dishwasher remove the screws securing it to the underside of the kitchen counter, close the water supply valve
under your sink, switch off the breaker at the electrical panel.
Most drain hoses are connected to the sink waste pipe with
a hose clamp. To disconnect the water supply remove the panel
below the door then undo the nut on the compression fitting.
You will have to lie on the floor to do this, you may also need a flashlight to see what you are doing.
Ken
Jan 03, 2015 | Kenmore Dishwashers
Instructions for installation of amana water inlet valve 12544001
I know that seems like the incorrect part but it replaces the water valve that had 2 outlet hoses connected to it. To replace that;
Turn off house water supply to old valve and disconnect tubing
remove old valve and unplug the 2 wire connections and the 2 outlet hoses
The two outlet hoses were what was considered a Y hose..cut off semi clear plastic tubing a inch back where the 2 semi clear plastic tubes merge and become only 1
pull one of the plastic nuts off of the Y tube
slip it onto the end of the newly cut single tube
slip single tube into outlet threaded outlet of new valve and tighten that plastic nut
connect the 2 wire plugs onto new valve
remount to back of refrig
attatch house water supply to metal fitting that has/had protective rubber cap over it (oh of course remove procetive rubber cap and discard it)
turn water supply back on
it may up to 4 hrs for water to flow to icemaker so best to test by dispensing water through freezer door
Good luck,any questions or problems please reply and i'll help you,
Gene
Aug 12, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Error 201 on the Meiko 40.2 undercounter. I am thinking that it is the float switch somewhere, the sump basin is filling up just fine. anybody have this problem?
Check that the water hose is correctly attached and is free of "kinks" or pinching. Also check that the water supply is turned on all of the way.
May 26, 2011 | Meiko FV 40.2 Dishwasher
Water leaking on to floor from dish washer. dishes not clean at end of cycle
You are going to need to verify the drain system on your unit.
Is the hose routed to the very top of the undercounter area, if not you can easily get other drain fluids into the dishwasher.
You need to verify the volume water that is coming out of the drain hose. Screens and hoses plug easily, in dishwashers.
Are you using soap labeled automatic dishwasher? Any other type of soap causes what you describe
Sep 16, 2010 | Dishwashers
Leaking dishwasher
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 29, 2009 | Asko Dishwashers
Leaking dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Feb 05, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Washer is overfilling
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 25, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
Apr 07, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
73 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
