Question about Panasonic KX-T7730 Corded Phone
My KX-T7730 can't display, no tone.
Hello, my telephone set (panasonic KX-T7730), with serial number 6CBKA015372, recently developed a fault, which I don't even know what to do about it yet. The phone has been in good condition till recently. I got to the office and discover that phone was no longer working. When I plug the cord, there's no display, no tone. Could you please assist me with some information on how to solve my phone problem. Thanks, Ebere.
  • 7 more comments
  • ewenikei May 25, 2009
    Dear Cnavarro,
    I never made any swap with any one. Before I left office on a weekend, the phone was ok. I discovered this problem on my resumption the next day.
    My dear,
    I have done all that. I have replaced the cord and the jack, which were confirmed to be ok in another phone.
    I'll go for a new phone then. Thanks for your effort.
  • Carl Navarro
    Carl Navarro May 11, 2010
    So that leaves a bad phone. Try Panasonic repair.
  • Carl Navarro
    ??? No, I'm saying SWAP the phone now with a known good one. You need to determine if the PHONE is bad, or the JACK is bad.
    You could have a bad handset, base cord, or phone, or the CLEANING person could have unplugged it.
  • Carl Navarro
    Did you swap the base with a known good one? Cords and all?
  • Jose Vasquez
    Jose Vasquez Feb 14, 2017
    hi carl
  • Jose Vasquez
    i need your help here in my KX-T7730
  • Jose Vasquez
    what was the proper color coding for the line cord of KX-T7730
    there was i dial tone but the light dose not lit and no display at all
    Problem Solver:
  • 16 Answers
KX-T7730 Phone must be connected with a 4wire line cord. you may be tested it with a 2 wire line connector.because other normal phones only needed 2wire line cords.Just connect a new 4w cord to under socket located to main unit & other end connect directly to the tel;system & see is the phone confirmed OK.
& let me know .Good luck.
[email protected]
Posted on May 27, 2009
SOURCE:
How to active caller id for panasonic kx-t7730
It depends what telephone system the KX-T7730 is connected to. You should have a Panasonic box that says 'KX-TA624', 'KX-TEA308, 'KX-TES824' or similar somewhere.
Depending which Telephone System you have, it may just need programming or it may need an additional card (circuit board) installing. Panasonic KX TEA TES Telephone Systems Tiny Telecom
Nov 23, 2016 | Panasonic KX-T7730 Corded Phone
Want to know how we can divert our Panasonic KX-T7730 to a mobile number
What you want to do is to activate the call forwarding feature offered by your phone company. Different phone companies have different procedures. With many companies you dial *72 then at the second dial tone dial the number to forward to. This number has to answer the call to activate call forwarding.For precise instructions please contact your telephone company.
Apr 25, 2012 | Panasonic KX-T7730 Corded Phone
How to configure panasonic exchange Model KX-TEM 824 to work with telemanager call tracking software using telephone KX-T7730
It's pretty straightforward. The DB-9 connector on the cabinet is turned on by default for incoming and outgoing calls, so all you have to do is connect your serial port to the Panasonic serial port at 9600,n,8,1 (default). In the Maintenance console, tab 1.7 adjusts the output. How you set up the software is part of the manufacturer's instructions. The Telemanager software on my search engine was designed for the NANP only.
Carl
Mar 01, 2011 | Panasonic KX-T7730 Corded Phone
How do I update the time on the panasonic kx-t7730
that is not pssible to set from telephone
there is a PABX device (panasonic kx-tes824 ) fixed in wall
from that PABX check 101 extension number (maybe 10, wich phone connected jack1 )
from there is only you can program
Please let me know this useful
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
How to set speed dial on panasonic kx-t7730
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00.
3. Enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial.
4. Press AUTO DIAL / STORE to save your setting.
5. To go to the next speeddial location press SP-PHONE and follow steps 3 and 4 again.
6. Press PROGRAM to exit program mode.
7. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
Apr 12, 2010 | Panasonic KX-T7730 Corded Phone
I don't know how to store spped dial numbers. I have 10 numbers to be stored to the Panasonic KX-T7730. Unfortunately the described way as per the users' manunal didn't work. Please help
If you are using the KX-T7730 phone on a Panasonic 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate / vote this answer if it was helpful.
Thank you.
Oct 05, 2009 | Panasonic KX-T7730 Corded Phone
I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
Sep 14, 2009 | Panasonic KX-T7730 Corded Phone
Resetting the Panasonic KX-T7730
go to menu .... settings.......rest. factory setting..
your security code is 0000 or 1234
try both code one by one.
when u change the code remember the new code.
Jul 28, 2009 | Panasonic KX-T7730 Corded Phone
Display most recent Caller ID telephone numbers not old ones
You have a 7730 PHONE. The system is not determined, but in analog going forward it could be a TA-624/824 or TAW-848.
If you have a TA system, it requires programming http://www.fixya.com/support/t2436730-caller_id_stoped_working_dont_know_clear
Carl
Jun 26, 2009 | Panasonic KX-T7730 Corded Phone
KX-T7730, all the phones connect with operator ring at the same time when having an incoming phone
please i need your help,i use KX-T7730 in my office and of recent when incoming calls comes in all the phones in the office starts ringing and also i would like to know how i can lock and unlock the phone so as to prevent other users from accessing it.Thanks
Apr 10, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
3,413 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
