Question about Panasonic CT-36SX12 36" TV
I need a 6.3 amp fuse but only have a 5 amp or 10 amp available
I am in Asia with a 120v device. I plugged it in to 240v, and the fuse blew. The fuse is 5mm x 20 mm 6.3 amp. The only other fuse available here is 5 amp or 10 amp. Can I use either of these?
Plugged it in and boom came the sound never worked is it because we in India use higher voltage.
Unless the device is switchable from 120V to 240V, you must use an inverter to operate it. Plugging a 120V appliance directly into a 240V outlet will always result in smoke and flames.
Apr 26, 2016 | Food Processors
Can I use this thermostat to control a 310w, 120v heat lamp load?
Voltage & Amperage are two different things. Check how much amperage iheat lamp requires. Rich
Apr 13, 2015 | Dimplex ETS610A1 Electronic Line Voltage...
GE microwave fuse model jes532wn rating 15v but what voltage rating: 120v or 240v ?.thanks
fuses do not have voltage ratings they are a current device. the 15 V does not make sense. It might be 15 A which is the current rating. A standing for Ampere which is the maximum current named after the discoverer of current creating magnetic fields being Andr?-Marie Amp?re in 1826. The 120v or 240v relates to the transformer design in the microwave. The transformer would be design to run on 240V AC 50 HZ AC like in Oz and UK or 120V 60 Hhz AC like used in the USA out of the power point from the power company.
Also the current relates to the voltage. So voltage divided by circuit resistance equals current.denoted by the formula I = V/R
Jan 24, 2015 | GE Microwave Ovens
Plug the 120v device into 240v outlet
Your air purifier most likely is fried.
Feb 26, 2018 | Honeywell Air Purifiers
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
I have a coleman powermate maxa 5000 er Generator. Model # PM0525202. The powercord plug came loose and burnt the plug and the receptical(240). I replaced the plug and receptical and I am not getting...
If this is the model I am thinking of, there are 3 outlets. One 240V (L1, L2, Neutral and Earth ground. Some models use a 3 terminal receptacle that combines Neutral and earth.), one 120V receptacle (L1, Neut, earth) and another 120V receptacle (L2, Neut, earth).
If you verified fuse and circuit breakers are good, turn on the generator and verify you get 120V on each of the two outlets. Measuring between the narrow blades of the two 120V outlets should be 240V.
***Shut off the generator.
With a test light or ohmmeter, check continuity from the earth terminal of 120V outlets to 240V outlet. Likewise for neutral (wider blade on 120V outlet). Lastly, check continuity from Narrow blade of each outlet to the 240V outlet.
I suspect that you miswired neutral and earth. On a 4 wire PLUG, it is customary to connect earth and neutral.
Work safely so you can give feedback.
Aug 30, 2017 | Coleman Electrical Supplies
Cdj 200s bought from america not working. they have american plugs on at 120v. i have tried an america to uk travel plug and 240v to 120v stepdown transformer but this has not resolved issue....... would...
Yes, fuse may be blown, first check out the fuse of CDJ,
if it does not work. Install a physical 120v American transformer
also change the switch of 240v to 120v from back of CDJ
thx,
djajay
Feb 07, 2010 | Pioneer CDJ-200 CD Player
I need the amount of amps used for multiple pieces of equipment
I'll hazard a guess that you are trying to run these things off of a single household electrical circuit and want to avoid an overload. In that case, the best way is to determine how many Watts each device uses. That information can either be found on the back/bottom of the unit, or on the AC adaptor that came with it. In the latter case, use the "input power" value.
Once you know the wattage, divide by the input voltage - 120 Volts in the US, 100 Volts in Japan, or 240 Volts in Europe, Australia, and much of Asia.
For example...the info on the bottom of my boombox indicates 120V at 16W...
Watts / Volts = Amps
18W / 120V = 0.15A
In another example, my laptop power supply has the following info...
120V-240V @ 160W input
15.4V @ 145W output
I use 120 Volts here so the math goes...
160W / 120V = 1.333A
Note that the output values are not used.
If I want to know how much current the devices use together, I merely add them...
Boombox Amps + Laptop Amps = Total Amps
0.15A + 1.333A = 1.483A
I hope this helps !
Marco
Feb 04, 2009 | Nikon CoolScan 9000 ED Film Scanner
110v - 240v
Well it may be compatible but it should hav a switch on the rear side to choose either 110 or 240V.Check for this but you probably burned primary side of main transformator and you'll have to replace it or to find somebody who is able to fix it
Feb 19, 2008 | Nakamichi SoundSpace 5 Shelf System
Panasonic CT-36SX12 36" TV Logo
113 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
