Question about Philips VR620CAT VCR
The colour has gone
The colour on my dvd/vcr has gone and there's no picture when i play a video can someone help please...
  • Dana Newcombe
    Dana Newcombe May 11, 2010
    Do the DVD's play alright, color and image etc.?
    President:
  • 1,564 Answers
You may have to clean the record/playback head. Firs remove the top casing and watch as the casette loads,making sure that it wraps the tape at least 1/3 of the diameter,this is of course not a precise measure but it will be close enough. If that's all well then you've got to clean the head. You can pick up the cleaning tool at your nearest electronics store(Radio Shack) and you'll need a small amount of denatured alcohol. While turning the head gently with one finger aplly a small amount of pressure with the dampened tool. Make several rotations. More importantly, after this, clean the three or four tiny slots at the base of the head(these actually do all the work. You can clean them buy rubbing back and forth with an old toothbrush soaked in denatured alcohol. Then spin the head while blowing through a straw to dry the unit, otherwise it will eat your first tape. Leave the top off and turn the unit on and off a couple times to do the final dry on the head then put in a tape and try it. Thanks Dana.
Posted on Aug 12, 2009
  • 159 Answers
Your banana pins are not good replace new
Posted on May 25, 2009
I have a collection of VCR tapes. They all will play sound but no picture - same in 3 different VCR players - please help!
Your current TV may not be "multi-system", which is needed to play tapes that have been recorded on a VCR that operates on a different "colour system". VCRs can be "multi-system" too, in which case, you select its output to match the playback TV's colour system. When you previously got the tapes to play, your VCR and TV were either "colour system matched" with each other (and the tapes), or "multi-system"
http://helpguide.sony.net/dsc/1510/v1/en/contents/TP0000576912.html
A simpler issue may just be a faulty video cable between the VCRs and the TV, assuming you used the same cable in all cases.
Nov 14, 2017 | Televison & Video
No picture on tv when playing dvd or video
does it have a picture for regular TV watching .if so then the dvd player has gone bad
Nov 22, 2015 | Panasonic Pv-d734s Dvd Vhs Player Combo...
There is no sound on my Sony SLV-D350P DVD Player / VCR Combo. The only section that works great is the VCR, but the DVD player sound just went out for some reason. I've changed the RCA cables, and...
Hi, As long as you have the picture it means that DVD's Laser Eye is Ok.. Pls Check your connections to make sure the audio and video cables of both VCR and DVD are properly hooked up to the television. Color coded cables should be matched with the jacks of equal color. Yellow corresponds to video while red and white are both audio.
Ensure the DVD is in standby mode if you are not getting picture from the VCR. The DVD cannot be running at the same time as the VCR is playing when you want to see the VCR picture.
Connections with combo units are often inconvenient, forcing you to use separate video hookups for each section (DVD, VCR), a problem for older TVs. This player has it figured out: a single RF or composite-video connection to a television will display either the DVD or the VCR signal, depending on which format you're viewing. If you want to view DVDs in S-video or in component-video (either interlaced or progressive-scan), you will need to use two inputs. though: any component- or S-video-equipped TV will offer sufficient inputs for both of the SLV-D350P's formats.
It's a different arrangement for audio: you can listen through a single set of stereo analog-audio cables for each component or--if you want to enjoy DVDs in discrete 5.1-channel surround sound--you can send the DVD's audio to a compatible audio/video receiver and a multichannel speaker system through a digital-audio interconnect (either optical or coaxial,). The unit also comes with an RF cable that will transmit DVD/VHS audio and video to your TV.
In conclusion,for a best tech solution I prpose you to connect DVD audio directly to your Stereo and listen as separate audio source.while Video goes to TV as usual. Hope this helps! if you need more help pls contact me..Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 02, 2011 | Sony SLV-D350P DVD Player/VCR
My lg video is only playing black and white films, the tv is still playing colour. It used to play colour videos at one time
try changing the colour options in the menu.
they are PAL,SECAM and others.try all of them till you find the one that matches your videos
Feb 14, 2011 | LG V271 DVD Player/VCR
DVDs are playing with green tinge
Greetings and Salutations,
If your using the component outputs from your DVD player I would first check to make sure that the cables for the Red and Blue channels are connected properly. If the cable is connected correctly then try replacing both the Red and Blue channel cable. If this fails to fix the problem try connecting to another component input on your TV if you have one available.
You might also want to check to see if you switched on the progressive scan switch on the back of the VCR/DVD unit. If you know someone with another DVD player have them bring it over and see if the problem is still exists.
If the green picture is still present then the problem is and internal problem with the TV and you will need to find a repair center for it. If the problem goes away then the problem is with the VCR/DVD combo unit. You can at this point also try using just the Video Out from the DVD player.
Hope these suggestions will help you with your problem.
Jan 06, 2009 | Toshiba SD-37VSR Player
Dvd/vcr sylvania combo
did a few google searches and suggestions were made to buy a**ther vcr...** way to fix the vcr heads. thanks anyways!
Mar 08, 2008 | Sylvania (SRDD495) DVD Player/VCR
FUNAI drvr-b778
Use a head cleaner to clean the heads on the vcr.
Jan 09, 2008 | Funai PY90VG DVD Player/VCR
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Can't get colour when playing back videos and dvd's
Is the picture still or it scrolls? You may be playing NTSC tapes and DVDs on a PAL TV or vice versa. If your TV supports multiple systems, try switching from one system to another (like NTSC from PAL).
Dec 14, 2007 | Sharp DV-NC80 DVD Player/VCR
Philips VR620CAT VCR Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
