Question about IBM WorkPad c500
Workpad c 500 chunk overlocked problem
When trying to print a screen after saving information, i get the message line 3061  chunk overlocked.  lt requires a hard reset to get the ibm workpad c500 to work again, and the information that was entered prior to the message is lost.
  • rtil Oct 20, 2007
    same thing happens to me.  what causes this?
Posted on May 06, 2009
I have HP Laserjet 5200N printer, i am not able to print due to error massege "10.00.00 Supply Memory Error". thanks Mohammad Hittini Director of IT Moevenpick Resort & Spa Dead...
Not sure if you have tried the HP knowledgebase, but there are a few steps they recommended trying.
Here is the direct link, but I copied the relevant information into my reply.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl51389&locale=en_US#A3
10.00.00 SUPPLIES MEMORY ERROR alternates with For help press ? Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 00 = memory is defective
yy
  • 00 = black print cartridge
Action
  1. Turn the printer power off, and then turn the printer power on again to clear the message.
  2. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 .
  3. If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
  4. Turn the printer on again.
  5. If the error does not clear, turn the printer off and remove Tray 3.
  6. Turn the printer on and verify if the error clears.
  7. If the error does not clear, contact HP support.
10.10.00 SUPPLIES MEMORY ERROR alternates with For help press ? Possible printer control panel error message 10.10.00 SUPPLIES MEMORY ERROR Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 10 = memory is missing
yy
Action
  1. Turn the printer power off, and then turn the printer power on to clear the message.
  2. If the message persists, click here to access to the HP support Web site at http://www.hp.com/support/lj2300 .
Jan 01, 2011 | Computers & Internet
PRINTING TWO EXTRA LINE ON @EJL 1284.4 @EJL ON EVERY FORM INVOICE AND CHECK EPSON LQ570+ RUNNING ON WINDOW 7
Windows 7 x64 & LQ-570+ ESC/P2 @EJL solution (should also work for other printers/OS, but not tested yet):
Try modifying .dpg file.
STEP 1:
Print the windows test page.
STEP 2:
There should be written the location and name of the file (Data file), so print the test page and look up the file path. It is located in the sam folder as dll (config file). In my case it is in "C:\Windows\system32\spool\DRIVERS\x64\3\".
(Sience I coulden't find x64 driver for LQ-570+ ESC/P2 I used LQ-590+ ESC/P2 Ver 2.0 driver. It's working ... )
STEP 3:
Now, when you found .GPD file, (make backup copy just in case) you have to add your computer account to list of accounts that has full controll of file or you won't be able to save changes.
STEP 4:
Delete only @EJLl 1284.4 and @EJL in line that looks like that:
*Cmd: "<0000001B01>@EJL 1284.4<0A>@EJL <0A1B>@<0D1B>t<011B>6<1B>R<001B>P<1B>(U<01000A>"
(If you delete anything else at that line it won't work ...)
STEP 5:
Save file an enjoy printig :P
If you have any question, write to riddle.xyz@gmail
Sep 01, 2010 | Epson LQ 580 Matrix Printer
Attachment line in Outlook message does not print
Highlight what you want to print and then choose "Print Selected" or you can take a screenshot, save in Paint and print the screenshot.
Mar 16, 2010 | Microsoft Office Outlook 2003 for PC
How to solve CRU Fuse error ?
Check the TONER Cartridge and Reinstall it
CRU Fuse Error
Means : The toner cartridge is not installed correctly
You can set the machine to ignore the “[Toner Empty]”
message and to continue printing incoming faxes.
Ignoring the Toner Empty Message
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button < or > until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button < or > to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Jan 21, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Ibm workpad sync & port issues help!
You have your Hotsync software set to use a com port instead of USB. Right Click on the Hotsync icon on the lower right part of your PC desktop and change it to USB and you should be good to go. The IBM Workpad is just like a Palm. I have the Workpad C500 which is actually a Palm M500. If you have a Workpad C505 it is a Palm M505. Anything you can buy for a Palm M500 will work with a C500 and anything you get for a M505 will work with a C505. If you do NOT have a USB Sync cable for your Workpad I suggest you do what I did... Just get a combination Sync and charge USB cable at Staples or Best Buy for your M500 or M505 and use it. It was about 20 but you can get them cheaper on the Net. I hope this helps you!
Sep 14, 2005 | IBM WorkPad z50
E-mail Does Not Synchronize To IBM Workpad When using Notes Client 6.0`
This issue was reported to Lotus software Quality Engineering, and has been addressed in EasySync Pro 4.2. Supporting Information: OBTAINING EASYSYNC PRO 4.2 If you are a Passport Advantage member, you can obtain EasySync Pro 4.2 through the Passport web site at the following URL: http://www.ibm.com/software/support/pa.html Otherwise, EasySync Pro 4.2 is available for purchase from the IBM web site at the following URL: http://www-306.ibm.com/software/info/ecatalog/ Should this URL not be available, you can go to the IBM web site, http://www.ibm.com, and choose the "Ready to buy" link. Related Documents: What Issues Have Been Addressed in EasySync Pro 4.2 and Where Can It Be Obtained? Document #: 197088 Related information What Issues Have Been Addressed in EasySync Pro 4.2 and Historical Number 196957
Sep 14, 2005 | IBM WorkPad c505
Support information - WorkPad c500/505
Support information - WorkPad c500/505 Applicable countries and regions Support information for WorkPad c500 / c505 (8602-60x/70x) *If you have problems with your WorkPad c500/c505, or Palm Desktop SW for IBM WorkPad, please visit the IBM Web site at URL: http://www.pc.ibm.com/support *If you have problems with the MS Outlook sync conduit (Pocket Mirror by Chapura), please visit the IBM Web site at URL: http://www.chapura.com *If you have problems with Lotus EasySync Pro, please visit the IBM Web site at URL: http://www.lotus.com *If you have problems with the trial version of DB2 Everyplace Personal Edition 7.1.2 (demo), please visit the IBM Web site at URL: http://www-4.ibm.com/software/data/db2/everyplace/support.html *If you have problems with IBM Mobile Connect 2.41 (trial), please visit the IBM Web site at URL: http://www-3.ibm.com/pvc/products/mobile_connect/index.shtml
Sep 14, 2005 | IBM WorkPad c500
Static electric discharge - IBM WorkPad c500, c505 (8602-60x / 70x) 2003-08-04
Palm Inc., the manufacturer of the IBM WorkPad, has recently informed IBM that a limited number of IBM WorkPad c500 and c505 models may be unable to use the HotSync function if a static electric discharge (ESD) takes place when the WorkPad is placed in the cradle. Palm Inc. has designed a new cradle for this condition. It has the Palm Inc. logo on it, but also works with these WorkPad models. Palm Inc. has a Web site that provides more information on this issue and also contains the Palm Cradle Exchange Program, which allows owners of eligible models to receive a new cradle. To determine if your WorkPad is eligible and to place an order for a replacement cradle, please visit the Palm Inc. Web site. NOTE: If you are in the Asia Pacific region, please contact the Palm Customer Information Centre in your country for information on how to recieve your replacement cradle. Links to this support information can be found at http://www.palm.com/asia/support/contact/asiapacificsupport.html NOTE: When ordering a replacement cradle from Palm, the entire IBM WorkPad serial number (16 digits) must be entered. The format is 1S8602MMMxxxxxxx (Where MMM is the 3 digit model number and xxxxxxx is the unique serial number).
IBM WorkPad c500 Logo
123 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
