Question about Sony Ericsson K750
Not working and no display
When i connected my phone to charger in between the charging it was swiched off,,,after that it was not working not displaying even,,,,,,,
  • 421 Answers
Battrey expired
Posted on May 25, 2009
Not charging
Hello My Dear Friend::::::::::"
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 12, 2013 | Sony Ericsson Z550i Cellular Phone
When I swiched on my mob 5130 c2 it does for seconds and swiched off by itself,but it's battry is very well charched
hi, at times battery will indicate well charged but they are not CHARGED... my advice is you try another battery and see if it will continue like that...but make sure the battery you will be trying is the original nokia battery, because if you still you use a fake battery, it will serve you for awhile before it will start given you problems.
Also, it could be that the charger is faulty, so try using another charger recommended by nokia.
cheers.
May 18, 2010 | Nokia 5130 Cellular Phone
ON\OFF buton is not responding. The phone is
The power (On/Off) button is not responding probably because it is broken, the phone is dead, or the battery is dead or drained. Connect the phone to a charger and check whether the phone charges the battery or not. The power button is indeed not responding and broken when the phone charges the battery. The only way to turn on the phone is by replacing the power switch.
When the phone doesn't charge the battery, the phone may be dead or the battery is dead/drained. To revive the battery and verify whether the phone is dead or not, check it here.
Apr 06, 2010 | Nokia 6233 Cellular Phone
No display to indicate battery is charging Nokia E63
to confirm that the phone is charging, switch on the mobile and charge or turn on the mobile when it is charging.if it doesn't works then try with some other charger,still same there is some problem with the battery r the connection point.check with the vendor.they will definitely assist u.
Aug 19, 2009 | Nokia Cell Phones
Red bulb led indicate when swiching on and phone doe s t start
This happens when your phone's battery is down. Connect it to the charger and make sure it's charging. Try turning it on after some fifteen minutes of charging.
Mar 15, 2009 | Sony Ericsson K800i Cellular Phone
Charging error
Charging error means that the phone charger is sending an incorrect voltage to the phone, or that there had been a contact on phone charger connector.
You can temporarily restart charging by unplugging and plugging back the charger, but on the long run this can damage the phone.
To start check the connector at the base of the phone, where you hook up the charger.
If there is dirt or oxide in there remove it, you can clean it using cotton buds and isopropyl alcohol.
If that does not solve the problem, go to any phone shop and buy a replacement AC charger for $10 or less.
Nov 09, 2008 | Sony Ericsson K600i Cellular Phone
Charging problem
if charger is problem it happen like this.
change your charger!
Jul 07, 2008 | Sony Ericsson K800i Cellular Phone
NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Feb 16, 2008 | Nokia 6630 Cellular Phone
Sony Ericsson K750 Logo
56 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
