Question about Panasonic EYC135NQKW 15.6 Volt Nimh Cordless 2 Tool Combo Kit, Includes 1/2 Inch Drill/Driver And Circular Saw
Drill overheated and will no longer move in reverse
Drill overheated and now will no longer move at all in reverse. Wondering if we can just replace the brushes or if the engine will need to be repaired and how much it would be to fix it.
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: new keyless chuck for panasonic drill ey690
Can'y find anything with the model number furnished, but generally to replace a chuck on a cordless you first have to remove the chuck screw LH threads and then shift the tool to the LOW position and the clutch to the drill only. Find a bent handle allen wrench about the same size as the chuck capacity and lock the smaller end in the jaws. Put the chuck on a work bench or block of wood with the handle at about a 30 degree angle so that you will be striking the wrench in the counter clockwise position, you might have to hit it a couple time but it will come off
Posted on Aug 10, 2009
  • 553 Answers
SOURCE: Moderrate resistance stops the drill from driving and to scream
The grinding you're hearing is the normal sound for the clutch. There's a ring with numbers on it the higer the setting the more torque it'll take for the clutch to slip. Many of the newer drill & drivers have a drill setting at the high end of the clutch settings others have a separate drill & driver setting. This site will give you most everything you need.
http://www2.panasonic.com/consumer-electronics/support/Building-Products/Cordless-Tools/Drill-Drivers/model.EY7542LN2L
Posted on May 30, 2010
  • 92 Answers
SOURCE: The drill trigger when pressed dosen,t work all
yes it can be fix,trigger swich seem to be bad
Posted on May 18, 2011
My lithium 20 volt drill is not working. the chuck is will not open and close. you cannot move the front and back sections independently so you cannot tighten a drill bit. How can I loosen the two...
Hold the chuck and run the drill either forward or in reverse until the chuck is fully closed or open then reverse it while holding chuck.
Jan 06, 2015 | Drills
Drills
It does not appear to be reversing. If it was it should have a lever right above the switch. Not worth much either since parts are no longer available to repair it.
Aug 18, 2012 | Black & Decker Drills
Electric Milwaukee drill locked in reverse
This is a common issue with drills, you can resolve the issue by purchasing a new trigger switch and installing it. It is a very simple task. all you will need is a screwdriver and about 10 minutes.
Mar 09, 2011 | Milwaukee Electric Drill 1/2in. Chuck...
3/8 " corded reverable drill. the jaws will not close around bit
If the jaws of the drill no longer works, then, the drill chuck must be replaced. Take it off by turning the chuck
counterclockwise, and putting an open wrench at its neck to lock it. Then, after taking it off, you can now have it replaced.
Nov 25, 2009 | Black & Decker 3/8" Variable Speed...
How do I remove and replace the keyless chuck on a makita hp1621F?
Remove the screw inside (clockwise)
mount a big Allen key in the chuck ,shortest part inside the chuck,
hurt the key with a hammer to make tre drill move counterclockwiseto unblock it
Nov 16, 2009 | Makita HP1621FK 5/8" Hammer Drill, 5.7...
The chuck no longer spins on my drill
Hi your best chance is to try ebay for one with the motor gone.
Other than that best you can do is buy another drill the same so you will have a spare battery.
You could try Skill for a gear but it probably will be the price of a new drill.
Oct 27, 2008 | Skil 2887 - 06 Factory - Reconditioned 18V...
Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Aug 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Panasonic EYC135NQKW 15.6 Volt Nimh Cordless 2 Tool Combo Kit, Includes 1/2 Inch Drill/Driver And Circular Saw Logo
90 people viewed this question
Top Panasonic Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Saw Expert? Answer questions, earn points and help others
