Question about Vacuums
Hoover Savvy #U5174-900 Vacuum
Does not pull forward or pick.  Feels like a broken belt but have check that and that is not the reason.
  • 1,673 Answers
If the belt is not turning the brush roll, then it could be different reasons. One is, is the switch in the handle ok, then there is a brush roll motor, 2 other circ. boards, one by the brush roll motor and the other behind the tool holder. I would look at the switch in the handle 1st, then go from there.
Posted on Jan 29, 2008
1) check the hose for blockage.
2) see the belt is slipin to due worn and replace .
3) check the bag/tank for full and need empty, and replace.
However go to the
and use the troubleshooting with common senses.
God bless you
Sep 06, 2012 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover savvy upright has no suction on carpet what's wrong?
9 times out of ten this is the response when you have a broken belt. The suction is the same but nothing gets picked up because there is no brush turning. Turn your machine off and see if you can turn the roller easily by hand. If you can you will need to change the vacuum belt.
If you are in Australia and need vacuum parts check out
May 12, 2012 | Hoover Vacuums
Brush will not turn and machine has stop self-propelling forward.
Two things to check out. 1- Any broken belts that need to be replaced? 2- Brush is frozen and needs to be removed, cleaned and lubricated and reassembled.
My guess is there is a problem with the belts.
Oct 04, 2010 | Hoover U8145-900 Savvy Bagless Upright...
My hoover windtunnel is not picking anything up all of a sudden. Also the roller underneith is not spinning. I've replaced filters and the attachment part is working fine, just when it's in the upright...
The belt that drives the brush roll has broken. That's why it doesn't pick up and why it doesn't pull itself forwards. Check the User Manual (download from Hoover website if necessary) for information on replacing the belt. Good luck!
Feb 05, 2010 | Hoover U6630-900 WindTunnel Bagless...
How to change belt on hoover savvy vacuum
How do I change the smaller brush belt on a Hoover Windtunnel Cyclonic?
Jan 11, 2010 | Hoover U8145-900 Savvy Bagless Upright...
Roller bars on bottom not rolling
The belt has probably broken. Hoover says that the belt on this model should last the life of the vacuum, but that is rarely the case. They do wear and break. Changing the belt is simple and the belts aren't to much. You can get a replacement here:
Savvy Replacement Belts
Oct 30, 2009 | Hoover U8145-900 Savvy Bagless Upright...
How do I install the timing belt on my Hoover Savvy Vacuum? Modle # u8174-900 Where is it located?
This is a parts schematic for your hoover savvy. You have to take off the brush guard on the bottom and also the cover on top (there is a screw under the round hoover logo). You will then see how the belt is attached. Very easy to do. Hope this helps
Jul 02, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
The vacuum turns on, but the thing with the bristles doesn't spin. Help?
no it can't be bypassed the motor is dc.the circuit board converts it from ac to dc
Apr 12, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Brush won't rotate when pushed forward
I had the same problem . The reason it acts like that is due to the cable that runs from the vacuum motor to the brush assembly has an intermittent open. My fix was to find the small cable that was causing my troubles and splice it. Making sure that I recovered the insulation. Of course my local repair station wanted to replace it for $75 labor plus parts and keep it for 3 days. I took it home and did it in 30 minutes .
Dec 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover Savvy
Does this happen at both Dirt Finder Sensitivity settings?
Sep 16, 2007 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Vacuums Logo
328 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
