Question about Canon iRC3100 Printer
I have a problem with the printer in ir 3100 cn
When i print from pc its very low density but when i copy from the fedr its good density .
thanks
  • 111 Answers
Change the printer properties setting on the computer from Normal or Draft where it is not to Best. That'll fix you up.
Posted on May 25, 2009
WHEN PRINTING ID CARDS THE PICTURE IS BLURRE BUT WHEN COPYING ORDINARY ORIGINAL IT IS GOOD.
Clean the Feeder glass with cleaner problem will be solved.
  1. For clear image decrease the Density.
  2. Clean the Laser Scanner and Reflectors(Mirrors).
Don't Do That
Do not use hard stain removers and alcohol while cleaning laser Scanner Lamp and Reflectors.
Also clean with a cotton.
Jun 13, 2016 | Canon Ir 3300 Black & White Copier
Getting light print on b&w, changing density makes zero change. Toner changed, no effect.
Check whether you are running as Black and White or Gray Scale. Many printers only print straight black by using all four toner cartridges- Cyan, Magenta, Yellow, black. If are running colored print in black and white and u choose grey scale it will automatically give you a screened image as a light print.
Mar 27, 2015 | Office Equipment & Supplies
What are the steps to solve light copies with canon ir 1024 copier
Did you clean the optik lens,mirrors...?It may also be a transfer roller,try to clean or replace it.
Sep 03, 2014 | Canon IR-1022 Copier
C7180 poor print quality
  • You printer may be running low on toner or the print density is too low.
  • Set the print density higher
  • Try turning printer off and on.
  • Print
Hope it helps.Thanks!
Sep 26, 2011 | Office Equipment & Supplies
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
Dell 3100 CN Prints a stip on black all the way
There is a known issue for these printers to "streak." If under warranty, call Dell. If not, there is a fix
for the defective drum unit design but requires a little technical expertise.
The procedure is explained here:
http://www.ahfx.net/weblog/133
Jul 08, 2009 | Dell 3100cn Laser Printer
Cannon IR 3100 CN Itermediate Transfer Belt error code E00070-000
The E00070-000 is not a ITB problem, but a full wastetoner. Open the front cover find the white bottle in the middle, remove the black screw, remove the cover over the top of the bottle and empty the bottle. Be sure to clean the top of the bottle so the sensor can see that the bottle is empty. Restart the copier.
Jun 04, 2009 | Canon iRC3100 Printer
Canon ir 3100 cn error code e000020-0081
HP Photosmart C 310series-driver Vindows Vista
Aug 09, 2008 | Canon imageRUNNER C3200 Copier
COF37 error code
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print1.gif cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website1.gif for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Jan 20, 2008 | Minolta CF2001 Copier
Code cof37
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print cycle, ATVC, or image stabilization sequence.
Step
Check Item
Result
Action
NO
NO
Clean or correct.
good contact.
YES
Dec 19, 2007 | Minolta CF2001 Copier
Canon iRC3100 Printer Logo
old marine
old marine
