Question about RCA Universal Remote Control
Closed captioning code for an Armstrong Cable UEI controller
Somehow I tripped into a code to select closed captioning with the controller. Now, the closed captioning is on ALL of the time and it is in the way of viewing many things. Can you help me get out of this mess?
I cannot imagine the original person still has this issue but if you turn off the cable box, assuming it is an HD PVR, you then hit the menu key and you can go into a whole bunch of options including cc
Posted on Mar 22, 2013
2 Suggested Answers
SOURCE: Closed caption on. Want it off.
the closed captioned in stuck in spanish on the screen does not move how do we remove this.
Posted on Jan 21, 2009
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
How to turn off closed caption
For over the air usually on the lower section of the remote look for CC or subt.
If on cable the Close Caption is controlled by the cable box not the TV. Usually there is a CC near the cable select button on the cable box remote. If not found then go into the cable box settings and look for
  1. Press the SETTINGS button
  2. Use the arrow buttons to scroll to the LANGUAGE section.
  3. Scroll to Closed Captioning and press the right arrow.
  4. Press the right arrow again and highlight the Off option
For some setups it is more complex. This link may help you with.
My Closed Captioning Won Turn Off
Jan 05, 2016 | Samsung Televison & Video
How to get rid of closed captioning
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network:
Setting Closed Captioning:
  1. Press and release the MENU button and then select "Preferences."
  2. Select "Closed Caption."
  3. Select "Caption On/Off."
  4. Select "CC is On."
  5. Select "Done."
Sep 20, 2011 | Sharp Televison & Video
We have a Sharp 25J-M100 and we cannot turn off the Closed Caption. We hit menu on our Sharp Remote Control and go down to Closed Caption and make sure it is off. The words never go off of the screen. Our...
If the captions are turned off on your TV, they have to be coming from your cable box. The TV is just displaying what it's getting. Check your cable box menu and make sure captions are turned off there. Cable boxes, especially on digital systems, can prevent the TV's caption decoder from operating properly. So they need to be able to provide captioning, and I suspect you've turned it on somehow. Comcast should be able to tell you how to turn off captions if you can't figure out the menus.
Jul 15, 2011 | Televison & Video
I have a vizio vw32l40a tv and cannot set closed captions. What do I do??
Hello
When selecting Closed Caption as a feature to be used; Closed Caption On Mute will provide you with
the option to obtain closed captioning when you press the key labeled mute on your Remote Control.
Press "Programme Down" button as many times as it takes to get this option highlighted.
Press either[=> /
Press the LAST key once to return to the previous screen or repeatedly to return to your program if task
has been completed.
Ok
Apr 09, 2011 | Televison & Video
We have tried several times over thelast few months BUT can NOT get the close caption to work....HELP!!!
Hello
There is a button on the remote control of your TV marked {CC}. This button is used to select the closed caption option to On and OFF. Presing it repetedly will change the options as described below.
CC/Stop - This button will select the Closed Caption menu
in the TV mode. Options include the following: OFF, CC1,
CC2, CC3, CC4, TT1, TT2, TT3 or TT4. Additionally, this
button stops the CD, DVD or VCR when the component is
activated with the remote control. If it doesn't work, means that button on your remote control is not working, and the remote control should be replaced. OK.
Feb 17, 2011 | Vizio L37 Television
How to turn closed caption off?
If the cc button on your Sharp remote control isn't turning them off then the captions may be coming from your cable box. The hidden menu to access closed captioning on the cable box is usually found by turning it off and then (yes I did say turn the cable box off) then press the menu button on the front of it immediately after turning it off. Then you navigate down to captions and disable them. When you turn the cable box back on the captions should no longer be there.
Feb 01, 2011 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Lost remote, somehow child turned on closed caption without remote,how do I disable closed caption without remote?
Find a button on the tv manual control said Menu,press it. Goto tv menu find and turn off all CC1,2,3 and text 1,2,3.U should have no more closed caption.
Sep 12, 2010 | Philips Magnavox 20MS233S 20" TV
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
Need codes for olevia tv
Olevia TV Remote Control Codes #tbltrouble TD { BORDER-BOTTOM: #cccccc 1px dotted; PADDING-LEFT: 2px }
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for all 2 Series, 3 Series, 4 Series, 5 Series, and 7 Series Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available, please call at 866-965-3842
Satellite TV Systems Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Cable TV Systems Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610
Jun 21, 2009 | Olevia LT27HVX 27 in. LCD Television
Televison & Video Logo
909 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
