Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis no error code keeps beeping low -loud
Keeps beeping when power button pushed, could this be a clogged filter?
  • 2 more comments
  • Alasandra Feb 06, 2008
    The machine seems to be working OK, in that it is washing clothes as far as I can tell.
    BUT IT KEEPS BEEPING!!!! all through the cycle. I would love to be able to make it stop beeping.
  • jjbiscuits May 06, 2008
    my washer cycle signal keeps beeping during and after the cycle has run. It washes the clothes fine, but the signal beeps on and off the whole time and then beeps every 20 seconds when the cycle is done.
  • Anonymous Mar 24, 2014
    power comes on but will not start when push the start button.
  • Anonymous Mar 29, 2014
    lights flash and beep when push the power button
Just bought a Kenmore Oasis He Canyon Capacity about a year and a half, everytime i go and push a different button it takes me to the Clean Washer light. I have to fool around with it for awhile before i can get it to the one i'm wanting, and after going through all of that problem, it beeps about 2 time every 20 second through the cycle.
Posted on Mar 21, 2008
MY WASHER IS BEEPING EVEN WHEN NOT IS USE.
Posted on Mar 19, 2008
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
If its the main board that you are having an issue with, honestly i will suggest to get a new one instead, might cost you as much as buying a new one if you are going to have it repaired.
May 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
I have a model 27096 top load kenmore elite oasis he washing machine that keeps flashing code F2 and keeps turning itself on. Help
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite oasis F2 (and beeping _
This code indicates a pump issue. First, remove and clean the filter. Then you need to check out the pump. Take a flashlight and look into the suction port on the pump. Check the impeller for broken or missing blades and make sure that the impeller moves freely. If any blades are broken or missing or if it won't move freely, the pump will have to be replaced. Hopefully, it is just clogged, but no matter how diligent we are, some items like coins, tacks, pens/pencils, or other hard items make it into the washer and some can end up at the pump and can damage the impeller or clog up the pump. Hope this helped and best wishes.
Sep 01, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE. I keep getting a F2 error and a beeping sound. Will happen at anytime, not just when using the machine. Washer had been unused for 2 days and all of a sudden the error code just...
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Aug 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore oasis electric dryer beeps and displays code F45
We had this error on our machine for about a year before we finally got sick and tired of it. Our dryer was purchased in 2006.
Here is the solution: the code means there is an error on the thermistor. Our thermistor was loose, as were other electrical wires. My husband tightened up all the connections and the thermistor, and we have never had this error again.
However, we will never buy these machines again either, because we have had numerous other errors on the washer and dryer.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Beeping
stuck key or bad control
Nov 09, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Cycle Signal beeping constantly
Hello dtaylorws,
You said,The cycle signal keeps alternating between loud and soft on its own and the other buttons will not function while this is happening, including the start button.
You could have a bed signal switch or control panel .
if the below suggestion failes or the problem returns you will need service!
Try unplugging the washer for 5 minutes and then restart it.
This should reset the system if there is a glitch like in a computer!
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
Like with an error code.
This can reset the system if it is electronic!
Unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works! Waiting for your reply!
Please remember to leave a rating when you are done!
Thank You huuum
Sep 20, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
264 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
