Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
Not feeding. I was in the middle of a project, everything was working fine. I switched to zig-zag stitch--it worked fine. Switched back to straight-stitch and it stopped feeding the fabric. Doesn't make sense--pretty new machine and I've barely used it.
  • 24 Answers
Check to see if the feed dogs are up, maybe you somehow clicked or switched a button, it happens to me some time when I take the bobbin out and put a new one in. I don't know your machine but some machines have the lever/knob for dropping the feed dogs in a strange location.
Posted on May 26, 2009
The feed dogs on my sewing machine will not raise
if your question is that the fabric didn't feed when I tried a zig-zag stitch , well then this might be a normal thing to happen on your machine , some machines when set to MAX size zig-zag stitch retract the "feed dogs" as you call them so that the operator can hand move the fabric around under presser foot , this is task called "darn" and its usually for filling large holes in fabric (socks!!) and for adding embroidery too (special needle)
Oct 05, 2016 | Sewing Machines
When making buttonholes, the machine will not zig zag in reverse when doing the right side of the buttonhole.
1. Remove the top.
2. Clean the inside with carburetor cleaner and lubricate with sewing machine oil.
3. While After this move the stitch length back and forth from a long arm to the reverse mode. Rotate the hand wheel several times to lubricate all moving parts.
4. Place some rags under the pressure foot and watch if the rags will back up.
5. Remove the bottom of the machine.
6. Clean the bottom moving parts and lubricate.
7. Rotate the hand wheel and watch the feed dogs to see if everything is moving.
8. It is possible to notice a screw attached to the stitch length adjuster that will have to be tightened. This may require you to move other parts that are attached and apply pressure while doing this.
Apr 02, 2015 | Sewing Machines
Bobbin unthreads my needle and will not sew
Try changing the needle to a new one, size 12, a dull or bent needle will cause this.
Jan 28, 2015 | Sewing Machines
Resolve the problem of not being able to Zig Zag on the Bernia 830. Ever4ything else works fine.
If you take the top off you will see the lever that connects with each cam, you can undo the screws on the cam and move it to make sure the lever is completely on the cam you want, if you have a nylon cam it may have splkit.
Jan 04, 2015 | Sewing Machines
Someone gave me a singer 403. I put in the zig zag attchment but it still sews only straight. What am I not doing??
Of course, you have to push the zig zag adjusment lever from the 1 position to one of the zig zag positions, 2-5. Also, the zig zag disc must be inserted. Take of the top of the machine (two screws to loosen the attachment and lift off the top), and you can see a steel connecting piece called the pitman and it should move back and forth when zig zag is engaged. If it isn't, maybe something is gummed up as has been suggested.
Jul 20, 2012 | Singer Sewing Machines
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 15, 2011 | Elna Sewing Machines
Singer Athena 2000 won't zig zag
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
Jun 08, 2009 | Singer Sewing Machines
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
May 23, 2009 | Bernina Virtuosa 150
The zag part of zig zag won't work
i believe your machine is skipping the stitch on the RIGHT side as you sew and this is normally a timing problem. Lower your needle about 1/16 inch and try it . It might work to finish your project but it will need to be serviced to have the timing corrected.
sewman7
Jul 28, 2008 | Necchi 3101 Mechanical Sewing Machine
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
245 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
