Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Problems scanning, i dont even have an icon
I cannot scan anything. i dont even have the scanner icon on my desktop. when i was installing my Epson Stylus NX100 all-in-one a window popped up saying the version of windows does not support. do i need to download a certain driver?
  • 30 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-15
Posted on Sep 04, 2009
    President:
  • 1,383 Answers
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
Epson scan icon missing
I have the same problem. Re-installing the 141mb Epson software does not fix the problem. I can print just fine but since there is no scan icon I am unable to scan. If I try scanning from the printer, it says "communication error". I'm fast approaching "junk it: stage and will search for another printer brand. Wasting way too much time on this one simple task.
May 21, 2012 | Epson Office Equipment & Supplies
My Epson RX650 scan software will not start up. The printer works and the copy feature works. When I double click on the Epson Scan icon on my desktop it appears that it wants to start up but then...
Install another scanning software, if you have photoshop or any imaging software, you can use the scanner by going to the menu, then choose File, Import, TWAIN, Acquire and the scanner control will appear.
Or just go to My Computer and double click the scanner icon (in XP) to start the scanning assistant.
Nov 09, 2010 | Epson Stylus RX650 All-In-One Printer
I don not have a scanner icon on my desktop so can't figure out how to scan . I have an epson printer scanner copier
When you installed the printer there should have been a program installed with it called Epson Scan. See if you can find it in your start menu under all programs. Otherwise, you may simply want to try installing it again, and tell it to place an icon on your desktop. You can find it at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=107546&prodoid=63076682&infoType=Downloads&platform=Windows. This is the epson support website, and the file you want is named "Scanner Driver and EPSON Scan Utility v3.49."
Hope this helps! Good Luck!
Nov 02, 2010 | Epson Stylus NX300 All-In-One InkJet...
Does the Epson tx100 actualkly have a scan function? I cannot find a button or way of working it.
Hello how are you.
Yes it have scanner on your printer but to use you need to do from your pc and go to users options and there you can see to use.
Hope this good for you thank you.
Usai
Mar 10, 2010 | Epson Stylus Multifunction Inkjet Printer/...
The 'EPSON Scan' desktop icon on my computer won't work.
Hopefully this is stilll relevant to somebody, but if you run the program as administrator you can get in
Jun 18, 2009 | Epson Stylus NX300 All-In-One InkJet...
Scanning using the DX8400 printer
You need to install the Epson Scanner Driver on your computer. The best way to do this is to install the sotware using the easy install facility. When the software installation has completed you will dind an Epson scan icon on your desktop. Double click this icon to run the scanner software.
The document to be scanned must be placed face down on the DX8400 glass just as making a copy, The scanning functions are all accessed from the PC.
I hope this helps.
Nov 14, 2008 | Office Equipment & Supplies
Scan copy to computer
Please check the original software disk that accompanied the scanner. You should have the option to install a twain or twain32 driver at the least, which would allow you to scan from within a graphics program (photoshop, or even paint).
Jul 04, 2008 | Epson Perfection 2400 Photo Flatbed...
Epson 4490 Photo - multiple PDF pages
Hi. Yours probably scans as soon as you have a document in and you double-click, right? I went through this. Double click on the Epson Icon. Make sure the mode preference at upper right is changed to professional. It may start scanning and you have to wait until it's finished to scan again. When you start in professional mode, it brings up a rectangular menu--you probably didn't see this one before (I didn't before changing to professional mode). Now press scan. This gives you a "file save" choice. Chose the location you want. Under the location choice is the Choose Document type option--this is the second key--save as PDF. Now it will bring up that add a page, edit or save file. Professional mode, save as PDF.
Dec 15, 2007 | Epson Perfection 4490 Film / Flatbed...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
273 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
