Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Blinking Light Problem on Ws-55513
After being off for three days. I went to turn the tv on. The little green light keeps blinking. I tried to reset it but no luck.  I have read the below fix, but need more info about it.
4 caps in the standup shielded module get bulges on top--obvious failure. Replace them. Seen it many times
Can someone explain what and where I should find these pieces.  Is it something that I can pull off and replace or is it something that involves soldering?  I would like to fix this myself.  Thank you very much.
Denny
  • 363 Answers
If bad capacitors are the problem then replacing them will involve soldering.
If the problem is something else less visible then fault finding will be difficult without the proper service manual.
http://www.completeservicemanuals.com/mitsubishi/crt-projection-television/ws-55513-service-manual/prod_37.html
This will show the correct disassembly and test procedures.
Good luck.
Posted on Oct 20, 2007
SOURCE:
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
Dec 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 blinking light
Try first unplugging power cord for one hour.
Oct 06, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking light
have the ppower transformer checked out when they go bad the tv wont come on
Oct 29, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Will not reset
Please verify Model number off back of set ! .........critical
for correct solution............For example...if your model # ends
with...13, then you will need to replace four capacitors in DM
module...1000mf 25v 105 degree.....if my guess is not correct,
the solution will be different.........................T.
Dec 18, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Will not reset
Oct 10, 2006 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
