Question about Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
Not recognized by any computer
I plug in my 4 GB Dane Elec flash drive and get an error "One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it." Is the drive salvagable?
    President:
  • 1,383 Answers
No it is supported on high speed or usb legacy 2.0
Go to bios setup and setr usb legacy 2.0 high speed
then save settigns
Posted on May 25, 2009
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
My usb device was working fine until yesterday when I plugged it in and I kept getting an Unknown device error with the following message: "Windows has stopped this device because it has reported...
Code 43 errors are nearly always caused by a driver issue. However, since you have tried the device in several different computers with the same result, I believe that your flash drive has gone bad or become damaged. Unfortunately this is not an uncommon problem with flash drives. Like any storage device on the computer, make sure you are backing up what is on your flash drive.
I hope this is helpful to you
May 28, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Put in my dane elec 16 gb flash key on my computer window ex and other computer window 2007 not recognized its malfunctioned. light is out... need to get all my important files out..
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htmwww.CardRecovery.com
Apr 20, 2011 | Dane-Elec DaneElec 4GB USB Drive Blue Hard...
My computer does not recognize me dane-elec 4 gb usb
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Mar 16, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
I have a Dane-Elec 4 GB Flash drive. I used it successfully one time, but the next time I put it in my computer (or any computer after that) the computer recognized the new device but told me "Please...
1) Instead of double-clicking, right-click and choose "explore." I hope it's that simple. Once you're in, look for a file called autorun.inf. Delete it.
2) If it won't let you explore, see if there is a "format" option instead. This will possibly solve your issue of access, and will solve your issue with your confidential data (of course, your data will be gone, but I'm guessing you're OK with that).
3) Try using another USB slot, sometimes there could be an issue with specific slots, especially if you are using hte front USB ports on a desktop
4) I know this may seem silly but turn off the computer, and then unplug the computer from the wall. Leave it unplugged for 30 seconds, plug it in and then boot up the systems. Plug in the USB drive.
5) Finally if the unit still is not being seen, it may need a low level format, contact the manufacturer and see about getting a replacement. I found their e-mail at onlinesupport@dane-memory.com
Feb 27, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Every time I plug it in first it says new device found then unknown device after it says one of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it.
Unfortunately that usually means that the drive has gone bad. Try using it in another pc- if the issue repeats, the flash drive has gone bad.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Dec 16, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
COMPUTER IS STATING THAT "THE
Sounds like it shorted out when you plugged it in the first time. I would return it and get a replacement. There is nothing you can do to fix it if this is the case.
Nov 03, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-Elec USB not working!
How I got it to work in XP Pro:
1) Plugged USB Drive in and saw it saw hardware manager install it but didn't see new Drive Volume in My Computer
2) Opened Control Panel
3) Open System
4) Clicked Device Manager from Hardware Tab
5) Expanded Disk Drives
6) Right clicked USB Flash Memory USB Device and hit Properties
7) Clicked Volume Tab and hit the Populate Button. Voila!
HTH
May 12, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive Logo
1,573 people viewed this question
Top Dane-Elec Computers & Internet Experts
Steve
woodzowl307
pankaj rautela
pankaj rautela
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
