Question about Google Chrome
Wireless connection problems, not receiving packets.
Heres my problem, when i sign in to my wireless, it says im connected but i receive very few packets. whenever i try to use a browser, no pages will load. but when i use my neighbors unsecured wireless i can access the internet and receive packets. im no techie but the only difference i could tell between the two, was that under properties, the working wireless was listed as open and disabled under network authentication and data encryption respectively. ive changed my firewall settings in norton and windows to allow my different browsers already and it seems like that cant be the problem if one wireless source works and another doesnt. Help!!
  • 108 Answers
Goto Network Connections >> Right Click on the wireless icon >> Properties >> Select IPv4(or IP for XP) >> Click on Properties >> Now see from your friend's system(in the same way) if here the details entered MATCH. The DNS entry shud match here.
Posted on May 25, 2009
  • 102 Answers
Did u set ur chrome settin to min level of security?
Vista have new router wireless network shows connected but not receiving packets
The problem is might be your computer is CONNECTED,but there are no network activity so you're receiving no packets
If you can't connected to the internet,then that network probably doesn't has an internet access on it
Aug 26, 2012 | Acer Aspire 7720-4428 Notebook PC
Fax machine does not receive FAX
The problem is that the codecs used by VoIP IADs are designed to compress voice, not the analog signals sent and received by modems.
In a VoIP Internet world, voice is first converted into packets and then they are sent over the connections that make up our our vast Internet. They may take slightly different times to arrive at their destination. In doing so some packets may be discarded, but the end result is that the receiving VoIP device has enough packets to make a clear and understandable conversation.
We suggest these settings on a fax machine for faxing over VoIP; slowing the transmission rate down and allowing the machine to continue receiving the transmission even though a few bits of data were lost, then faxing over VoIP can become more consistent. Our suggestions in many cases can resolve issues that prevent faxing over a VoIP connection, but not in all cases. If after trying and making all the VoIP fax changes we suggest you still cannot fax over your connection then try a Internet Fax service.
Aug 10, 2011 | HP Office Equipment & Supplies
I'm having trouble receiving packets from wireless
For starters when the wireless card gets bad..usually you couldn't see the signal or nearby wireless broadcast.
I assume you can see it, because you said you got problems with packets.
it could be cause by many factors.
Wireless router misconfigurations, but the most common is interference.
If your wireless router is broadcasting in the same channel as ...lets say a cordless phone...your connection will be dropping frequently.
Also, neighbors using the same channel as well can cause the same problem.
Seems to me that the problem is in the wireless router, and not in your wireless card.
Don't forget to rate this answer if it helps.
Dec 27, 2009 | Sony VAIO VGN-C140G/B Notebook
My Local Area Network icon Indicates that iam connected but i can't get internet.Sends few packets the received ones freezes. Andrew From Kenya
Log in as a Adminstrator
open the command prompt or click on run and type cmd , then enter.
Type the following commands
ipconfig / release
ipconfig /flushdns
netsh winsock reset
after you done , restart the computer .
It should work now
Apr 14, 2009 | Computers & Internet
Have internet connection but browser won't open
There are a number of choices to get it working so let's try one at a time:
Click start>run>type cmd to get to DOS prompt>then type ping 127.0.0.1. You should see some packets being sent and packets being received. This is to test that your network card is working. If you do not get any packets received then your network card is bad. If you do get packets received then let me know there are still a couple of options.
Mar 19, 2009 | Dell Inspiron 1501 Notebook
Can NOT Connect to the Internet...
use correct ip address and DNS address and the n check the connection with domain and then connect it to internet. use ping with ip address to check the modem performance.
Aug 16, 2008 | Dell OptiPlex GX260 PC Desktop
Connecting laptop to wireless modem/router after formatting HDD
please lemme know about your'e ISP when they were setting up you wireless network, did they gave you any ip address or something ? ask them and lemme know
peace!
Jul 04, 2008 | Computers & Internet
No internet packets received
1. just check the lan card is enbled
example:my network place --right click---properties---wireless lan card,
2. check the R u getting ip address,
example: start---run---cmd----ipconfig
May 08, 2008 | Toshiba Satellite M115-S1061 Notebook
Google Chrome Logo
467 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
